rohmer
1
Figured this would be helpful for people.
In the UI Creator there are options for everything within LVGL (Boy is this a lot of tying to do, but in the end will make it complete).
For example Button Maps, each button has 6 options (No Repeat, Inactive, etc). Well in order to record the UI changes we need a call back.
In order to minimize the number of different call backs, what I did was:
- Create a single call back for all of the options.
- In the call back do this:
if (event != LV_EVENT_VALUE_CHANGED)
return;
std::string option = lv_cb_get_text(obj);
Since each cb option has different text, I can assign the value based on that, and have a single call back for all checkboxes.
Easy pizzy.
rohmer
2
The whole function, for completeness
void BtnmEditorWindow::optCB(lv_obj_t* obj, lv_event_t event)
return;
bool checked = lv_cb_is_checked(obj);
uint16_t flag = 0;
if (option == "Hidden")
flag = LV_BTNM_CTRL_HIDDEN;
if (option == "No Repeat")
flag = LV_BTNM_CTRL_NO_REPEAT;
if (option == "Inactive")
flag = LV_BTNM_CTRL_INACTIVE;
if (option == "Toggle Enable")
flag = LV_BTNM_CTRL_TGL_ENABLE;
if (option == "Toggle State")
flag = LV_BTNM_CTRL_TGL_STATE;
if (option == "Click Trigger")
flag = LV_BTNM_CTRL_CLICK_TRIG;
if (flag != 0)
if (checked)
buttons[selectedButton].ctrlBits = buttons[selectedButton].ctrlBits |= flag;
buttons[selectedButton].ctrlBits = buttons[selectedButton].ctrlBits &= ~flag;
// Reset all the ctrl bits
static std::vector<lv_btnm_ctrl_t> ctrlMap;
ctrlMap.clear();
for (int i = 0; i < buttons.size(); i++)
ctrlMap.push_back(buttons[i].ctrlBits);
lv_btnm_set_ctrl_map(preview, ctrlMap.data());
Yes, it’s good idea to re-use event callbacks. Thanks for sharing!
An other option to identify the objects with their user_data
rohmer
4
Absolutely on user_data. I use it extensively.
In this case it was not necessary, because there was already a differentiator on the text.
Within LVGL UI Creator, normally I have code for creating objects, which in turn all use a similar call back. For example Text Areas.
All text areas need the following:
- Set them active when clicked upon to get keyboard input (Also deactivate all of the ones in the group)
- Set the variable they are tied to when they are changed
- Some other internal things like reset the object with the variable’s new data, etc.
So, using this paradigm, I simply have code that creates the TA, and registers to a single callback for each of the text areas.
