Updating lvgl bar value
Hi
I have an ESP32 water level monitor setup using ESP32 Now (1 master ESP32 and 1 slave ESP32CYD) and I can succesfully transmit date between the two and show the data on the CYD using lvgl.
I have created a bar to show the level of the water and I wish to change this when the received data changes.
I can create the bar and set the initial value, however, when I try to change the bar value using lv_bar_set_value(bar1, myData.c, LV_ANIM_ON);, I get the following error message on the Arduino IDE serial monitor and the screen does not update anything.
[Error] (0.005, +5) lv_bar_set_value: Asserted at expression: obj != NULL (NULL pointer) lv_bar.c:102
The CYD is still receiving data succesfully.
I have tried putting the lv_bar_set_value(bar1, myData.c, LV_ANIM_ON) in the main loop and within the function that updates the screen text
My code below is only 180 lines
/* ESP Now Water Level Monitor Reciever */
#include <esp_now.h>
#include <WiFi.h>
#include <lvgl.h>
#include <TFT_eSPI.h>
#define LCD_BACKLIGHT_PIN 27
#define SCREEN_WIDTH 320
#define SCREEN_HEIGHT 480
#define DRAW_BUF_SIZE (SCREEN_WIDTH * SCREEN_HEIGHT / 10 * (LV_COLOR_DEPTH / 8))
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
// Theme Colors
#define THEME_COUNT 2
uint32_t theme_bg_top[THEME_COUNT] = {0xA8FFE3, 0x2c3e50}; // Light teal, Dark blue
uint32_t theme_bg_bottom[THEME_COUNT] = {0x56E3C3, 0x1a2530}; // Dark teal, Darker blue
uint32_t theme_card[THEME_COUNT] = {0x4FD7B7, 0x34495e}; // Card color
uint32_t theme_accent[THEME_COUNT] = {0x223a5c, 0xecf0f1}; // Text color
uint32_t theme_separator[THEME_COUNT] = {0xc0c0c0, 0x606060}; // Separator colors
#define SEPARATOR_OPA 0x22
int level;
// UI Elements
static lv_obj_t *scr_home;
static lv_obj_t *lbl_desc, *lbl_dist, *lbl_perc;
lv_obj_t * bar1;
TFT_eSPI tft = TFT_eSPI();
SPIClass touchscreenSPI = SPIClass(VSPI);
// Structure to receive water level data
// Must match the sender structure
typedef struct struct_message {
char a[32]; // Input Description
int b; // input measurement in mm
int c; // input measurement as %
int d; // random number to check messages are changing
} struct_message;
// Create a struct_message called myData
struct_message myData;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
memcpy(&myData, incomingData, sizeof(myData));
Serial.print("Bytes received: ");
Serial.println(len);
Serial.print("Char: ");
Serial.println(myData.a);
Serial.print(“Depth: “);
Serial.print(myData.b);
Serial.println(” mm”);
Serial.print(“Fill Level: “);
Serial.print(myData.c);
Serial.println(” %”);
Serial.print("Timestamp: ");
Serial.println(myData.d);
Serial.println();
void update() {
lv_label_set_text(lbl_desc, myData.a);
lv_label_set_text_fmt(lbl_dist, “%d mm”, myData.b);
lv_label_set_text_fmt(lbl_perc, “%d%%”, myData.c);
//lv_bar_set_value(bar1, myData.c, LV_ANIM_ON); // This is where the code fails and stops the sceen updates
void setup_home_screen() {
scr_home = lv_obj_create(NULL);
lv_obj_set_scrollbar_mode(scr_home, LV_SCROLLBAR_MODE_OFF);
lv_obj_set_style_border_width(scr_home, 0, 0);
lv_scr_load(scr_home);
// Description
lbl_desc = lv_label_create(scr_home);
lv_obj_set_style_text_font(lbl_desc, &lv_font_montserrat_36, 0);
lv_obj_set_style_text_color(lbl_desc, lv_color_hex(0x223a5c), 0);
lv_obj_align(lbl_desc, LV_ALIGN_TOP_LEFT, 14, 14);
lv_label_set_text(lbl_desc, "");
// Measurement
lbl_dist = lv_label_create(scr_home);
lv_obj_set_style_text_font(lbl_dist, &lv_font_montserrat_36, 0);
lv_obj_set_style_text_color(lbl_dist, lv_color_hex(0x223a5c), 0);
lv_obj_align(lbl_dist, LV_ALIGN_TOP_LEFT, 14, 44);
lv_label_set_text(lbl_dist, "---mm");
// Percentage
lbl_perc = lv_label_create(scr_home);
lv_obj_set_style_text_font(lbl_perc, &lv_font_montserrat_36, 0);
lv_obj_set_style_text_color(lbl_perc, lv_color_hex(0x223a5c), 0);
lv_obj_align(lbl_perc, LV_ALIGN_LEFT_MID, 14, 0);
lv_label_set_text(lbl_perc, "--%");
// Percentage bar
lv_obj_t * bar1 = lv_bar_create(lv_scr_act());
lv_obj_set_size(bar1, 50, 200);
lv_obj_center(bar1);
lv_obj_align(bar1, LV_ALIGN_CENTER, 0, 0);
lv_bar_set_value(bar1, 70, LV_ANIM_ON);
apply_theme();
void apply_theme() {
if (scr_home) {
    lv_obj_set_style_bg_color(scr_home, lv_color_hex(0xA8FFE3), 0);
    lv_obj_set_style_bg_grad_dir(scr_home, LV_GRAD_DIR_NONE, 0);
void update_brightness() {
analogWrite(LCD_BACKLIGHT_PIN, 255);
static void disp_flush(lv_display_t * disp, const lv_area_t * area, uint8_t * px_map) {
tft.startWrite();
tft.pushColors((uint16_t *)px_map, w * h, true);
tft.endWrite();
lv_display_flush_ready(disp);
void setup() {
// Initialize Serial Monitor
Serial.begin(115200);
pinMode(LCD_BACKLIGHT_PIN, OUTPUT);
analogWrite(LCD_BACKLIGHT_PIN, HIGH);
// Initialize TFT
tft.begin();
tft.setRotation(0);
tft.fillScreen(TFT_BLACK);
// Create a display object
lv_display_t * disp;
// Initialize the TFT display using the TFT_eSPI library
disp = lv_tft_espi_create(SCREEN_WIDTH, SCREEN_HEIGHT, draw_buf, sizeof(draw_buf));
//lv_display_set_rotation(disp, 0);
delay(10000);
setup_home_screen();
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
Serial.println(“Error initializing ESP-NOW”);
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(esp_now_recv_cb_t(OnDataRecv));
void loop() {
lv_timer_handler();
lv_tick_inc(5);
delay(5);
update(); // call update function to update values on the screen
Picture of the CYD screen
  • ESP32 CYD - E32N40T (non touchscreen):
  • **LVGL version: 9.5.0 **`
@colinm001, Thank you for sending the message. Well, analyzing your code, I noticed that you are using the same variable name for both local and global variables.
lv_obj_t* bar1; // global
// Percentage bar
lv_obj_t * bar1 = lv_bar_create(lv_scr_act()); // Local variable (once called, this variable will be destroy.)
You can use just the global varaible. Here the result:
Thank you for getting back to me so quickly.
Sorry for appearing stupid, but I’m not sure how to just use the global variable for this to work
No problem.
Are you able to show me where to change the code to get this to work?
Sure, here is:
// UI Elements
lv_obj_t * bar1;
static int32_t bar_value = 40;
void update() {
lv_label_set_text(lbl_desc, "Water Level");
lv_label_set_text_fmt(lbl_dist, "%d mm", 256);
lv_label_set_text_fmt(lbl_perc, "%d%%", 38);
lv_bar_set_value(bar1, bar_value, LV_ANIM_ON); // This is where the code fails and stops the sceen updates
if (scr_home) {
// Description
// Measurement
// Percentage
lv_label_set_text(lbl_perc, "--%%");
// Percentage bar
bar1 = lv_bar_create(scr_home);
apply_theme();
Thank you very much, thats work perfectly.
I wouldn’t have had a clue without your help.
Bonjour, je me permets de vous écrire car je viens d’acheter le même écran que vous E32N40T et je n’arrive pas à configurer Vscode et platformio.ide pour faire fonctionner cet écran même pour un simple affichage, je pense que j’ai un problème avec le driver ou la bibliothèque tft_espi … pouvez vous m’aider à configurer mon code dans vs code ? merc d’avance et cordiales salutations. Philippe
Hi Philippe
My apologies for not replying in French.
I am using the Arduino IDE, not VS
This article shows how to get the TFT-eSPI library wirking with VS Cod and PlatformIO
I used the following configuration to set up the E32N40T in my User_Setup.h file for the TFT-eSPI driver
ST7796_DRIVER
TFT_BL 27
TFT_MISO 12
TFT_MOSI 13
TFT_SCLK 14
TFT_CS 15
TFT_DC 2
TFT_RST -1
TFT_WIDTH 320
TFT_HEIGHT 480
Please note that the colour order is BGR for this display
Here is my trimmed down User_Setup.h
User_Setup.h (2.8 KB)
After much serching in Google I did find the user manual, which I have attached below.
4.0inch_ESP32-32E_E32R40T_E32N40T_User_Manual.pdf (1.3 MB)
According to the article, you should be able to use these pin allocations in your platformio.ini file.
I hope this is of help
Colin
Merci Colin pour votre réponse rapide et c’est moi qui vous prie de m’excuser pour mon français.
Vos indications et liens sont précieux et je vais faire des tests avec tout çà.
Juste encore une petite demande, pourriez vous me partager votre projet sous Arduino (que je vais installer) pour tester cet écran enfin :wink:
Merci d’avance,
Philippe
merci Colin je viens de tester un sketch de base et j’ai réussi à afficher “Hello World” sur cet écran et sous arduino, j’ai juste remplacer le fichier User_Setup.h de la bibliothèque TFT_eSPI de Bodmer par le fichier que vous avez donné plus haut, il me reste maintenant à tranposer ceci pour que cela fonctionne aussi sous Vscode et Platformio.ide.
Encore un grand merci pour votre aide qui m’a permis d’enfin avancé avec cet écran.
Cordiales salutations
:+1:
