Updated Lovyan lib? can't find getRotation(), width(), heght()
I had a LVGL project working fine a couple of months ago. I had to spend time working on a different part of the project. Now I’m ready to go back to it, “supposedly”, all I had to do was change an HTTP address and it would be good to go.
But platformio blew up. I think I finally got that working.
But now it looks like Lovyan library and/or LVGL got updated. Platformio (running as pioarduuino) now errors out on:
lv_lovyan_gfx.cpp, can’t find getRotation() or width() or height().
I noticed those two files, the older version and the newer one are different sizes, and the calls mentioned are not in the older version.
Any suggestions on how to fix this one? I’m guessing my “class LGFX : public lgfx::LGFX_Device” needs to be modified, but I’m not sure where or how.
  • MCU/MPU/Board:
  • LVGL version: See lv_version.h
I ran into the same problem. The reason seems to be that I named my LGFX config lv_lgfx_user.hpp like the default lv_config.h uses. Unfortunately, LVGL already supplies a file by that name and it was being loaded ahead of my definitions. So the answer is to name your config something else and update lv_conf.h to reference that file.
Note that the above change got me through the build and upload phases, but now the code “boot loops” when executed. So…on to the next issue…
