Hi @all,
I´m using this UI (generated with SquareLine Studio)
// This file was generated by SquareLine Studio
// SquareLine Studio version: SquareLine Studio 1.6.0
// LVGL version: 9.3
// Project name: Calendar
#include "../ui.h"
lv_obj_t * ui_screenstatus = NULL;
lv_obj_t * ui_screenstatusheader = NULL;
lv_obj_t * ui_screenstatuslabelbattery = NULL;
lv_obj_t * ui_screenstatuswifi = NULL;
lv_obj_t * ui_screenstatusstatuslabel = NULL;
// event funtions
void ui_event_screenstatus(lv_event_t * e)
if(event_code == LV_EVENT_SCREEN_LOADED) {
ScreenStatusLoaded(e);
// build funtions
void ui_screenstatus_screen_init(void)
ui_screenstatus = lv_obj_create(NULL);
lv_obj_remove_flag(ui_screenstatus, LV_OBJ_FLAG_SCROLLABLE | LV_OBJ_FLAG_SCROLL_ELASTIC |
LV_OBJ_FLAG_SCROLL_MOMENTUM); /// Flags
ui_screenstatusheader = lv_obj_create(ui_screenstatus);
lv_obj_remove_style_all(ui_screenstatusheader);
lv_obj_set_height(ui_screenstatusheader, 70);
lv_obj_set_width(ui_screenstatusheader, lv_pct(100));
lv_obj_set_align(ui_screenstatusheader, LV_ALIGN_TOP_MID);
lv_obj_remove_flag(ui_screenstatusheader,
LV_OBJ_FLAG_CLICKABLE | LV_OBJ_FLAG_PRESS_LOCK | LV_OBJ_FLAG_CLICK_FOCUSABLE | LV_OBJ_FLAG_GESTURE_BUBBLE |
LV_OBJ_FLAG_SNAPPABLE | LV_OBJ_FLAG_SCROLLABLE); /// Flags
ui_screenstatuslabelbattery = lv_label_create(ui_screenstatusheader);
lv_obj_set_width(ui_screenstatuslabelbattery, 150);
lv_obj_set_height(ui_screenstatuslabelbattery, LV_SIZE_CONTENT); /// 1
lv_obj_set_x(ui_screenstatuslabelbattery, -20);
lv_obj_set_y(ui_screenstatuslabelbattery, 0);
lv_obj_set_align(ui_screenstatuslabelbattery, LV_ALIGN_RIGHT_MID);
lv_label_set_long_mode(ui_screenstatuslabelbattery, LV_LABEL_LONG_MODE_SCROLL);
lv_label_set_text(ui_screenstatuslabelbattery, "100%");
lv_obj_remove_flag(ui_screenstatuslabelbattery,
LV_OBJ_FLAG_PRESS_LOCK | LV_OBJ_FLAG_CLICK_FOCUSABLE | LV_OBJ_FLAG_GESTURE_BUBBLE | LV_OBJ_FLAG_SNAPPABLE |
LV_OBJ_FLAG_SCROLLABLE | LV_OBJ_FLAG_SCROLL_ELASTIC | LV_OBJ_FLAG_SCROLL_MOMENTUM |
LV_OBJ_FLAG_SCROLL_CHAIN); /// Flags
lv_obj_set_scrollbar_mode(ui_screenstatuslabelbattery, LV_SCROLLBAR_MODE_OFF);
lv_obj_set_style_text_align(ui_screenstatuslabelbattery, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui_screenstatuslabelbattery, &lv_font_montserrat_28, LV_PART_MAIN | LV_STATE_DEFAULT);
ui_screenstatuswifi = lv_label_create(ui_screenstatusheader);
lv_obj_set_width(ui_screenstatuswifi, 200);
lv_obj_set_height(ui_screenstatuswifi, LV_SIZE_CONTENT); /// 1
lv_obj_set_x(ui_screenstatuswifi, -200);
lv_obj_set_y(ui_screenstatuswifi, 0);
lv_obj_set_align(ui_screenstatuswifi, LV_ALIGN_RIGHT_MID);
lv_label_set_long_mode(ui_screenstatuswifi, LV_LABEL_LONG_MODE_SCROLL);
lv_label_set_text(ui_screenstatuswifi, "-35 dBm");
lv_obj_remove_flag(ui_screenstatuswifi,
lv_obj_set_style_text_align(ui_screenstatuswifi, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui_screenstatuswifi, &lv_font_montserrat_28, LV_PART_MAIN | LV_STATE_DEFAULT);
ui_screenstatusstatuslabel = lv_label_create(ui_screenstatus);
lv_obj_set_width(ui_screenstatusstatuslabel, 300);
lv_obj_set_height(ui_screenstatusstatuslabel, LV_SIZE_CONTENT); /// 1
lv_obj_set_align(ui_screenstatusstatuslabel, LV_ALIGN_CENTER);
lv_label_set_long_mode(ui_screenstatusstatuslabel, LV_LABEL_LONG_MODE_SCROLL);
lv_label_set_text(ui_screenstatusstatuslabel, "Loading");
lv_obj_remove_flag(ui_screenstatusstatuslabel,
lv_obj_set_scrollbar_mode(ui_screenstatusstatuslabel, LV_SCROLLBAR_MODE_OFF);
lv_obj_set_style_text_align(ui_screenstatusstatuslabel, LV_TEXT_ALIGN_CENTER, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui_screenstatusstatuslabel, &lv_font_montserrat_40, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_add_event_cb(ui_screenstatus, ui_event_screenstatus, LV_EVENT_ALL, NULL);
void ui_screenstatus_screen_destroy(void)
if(ui_screenstatus) lv_obj_del(ui_screenstatus);
// NULL screen variables
I get weird scrolling bars, when I change the text of the status label and the battery label (see the picture) with one of these functions:
void ScreenStatus_UpdateRSSI(int8_t RSSI)
char Buffer[16];
/* Only update the value if it has changed */
if ((strcmp(lv_label_get_text(ui_screenstatuswifi), Buffer) != 0) && (ui_screenstatuswifi != NULL)) {
snprintf(Buffer, sizeof(Buffer), LV_SYMBOL_WIFI " %d dBm", RSSI);
lv_label_set_text(ui_screenstatuswifi, Buffer);
void ScreenStatus_UpdateText(const char* Text)
if ((ui_screenstatusstatuslabel != NULL) && (Text != NULL)) {
lv_label_set_text(ui_screenstatusstatuslabel, Text);
I´m not sure where they come from and how to disable them.
