Hi, I met a problem only with “two screen-sized” buffers. (All the other settings are the same)
When I want to delete objects or add objects, I need to call lv_obj_invalidate(lv_scr_act()) to make the result correct.
If I do not call that, it would be empty after the second lv_refr_now.
Can someone kindly give me some suggestion?
Does it cause by flush_cb?
Can some kindly tell me how can I write flush_cb to operate successfully?
I’ve tried another test to add an obj. (un-comment the code for button3)
If I do not call lv_obj_invalidate(lv_scr_act()), the result only draws the area which needs to be re-drawn.
But the areas that do not have to be re-drawn (button1,button2) do not contain in the buffer(show on the screen).
Do I need to invalidate whole screen every time to make all objects re-draw to the buffer?
I want to directly use the given-buffer as my display buffer.
void Demo(){
lv_obj_t * button = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_size(button, 300,300);
lv_obj_set_pos(button, 250,250);
lv_obj_add_style(button,LV_OBJ_PART_MAIN,&style1);
lv_obj_t * button2 = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_size(button2, 100,100);
lv_obj_set_pos(button2,100,100);
lv_obj_add_style(button2, LV_OBJ_PART_MAIN,&style1);
lv_refr_now(NULL);
usleep(1000*1000*2);
lv_obj_del(button2);
// lv_obj_t * button3 = lv_obj_create(lv_scr_act(), NULL);
// lv_obj_set_size(button3, 100,100);
// lv_obj_set_pos(button3,500,500);
// lv_obj_add_style(button3, LV_OBJ_PART_MAIN,&style1);
lv_obj_invalidate(lv_scr_act());
lv_refr_now(NULL);
void my_disp_flush_ex(struct _disp_drv_t * disp, const lv_area_t * area, lv_color_t * color_p){
int32_t x1 = area->x1;
int32_t x2 = area->x2;
int32_t y1 = area->y1;
int32_t y2 = area->y2;
uint32_t w = x2 - x1 + 1;
for(int32_t y = y1; y <= y2; y++) {
memcpy(&tft_buf[y * LV_HOR_RES_MAX + x1], color_p, w * sizeof(lv_color_t));
color_p += w;
//SDL_UpdateTexture(gTexture, NULL, disp->buffer->buf_act, LV_HOR_RES_MAX * sizeof(uint32_t));
SDL_UpdateTexture(gTexture, NULL, tft_buf, LV_HOR_RES_MAX * sizeof(uint32_t));
SDL_RenderClear(gRenderer);
SDL_RenderCopy(gRenderer, gTexture, NULL, NULL);
SDL_RenderPresent(gRenderer);
lv_disp_flush_ready(disp); //Indicate you are ready with the flushing
