Uneven button size for keyboard map
Hi
when i try to set new keyboard map for keybaord i seen irregular button size
the first 1,2,3 numbers are perfectly fit to horizontal width.
how to resolve this issue
ARM
v7.11
//Custom map
    static const char * kb_map[] = {
                  "1","2", "3","\n",
                  "4", "5", "6","\n",
                  "7", "8", "9","\n",
                  " ","0"," ", LV_SYMBOL_BACKSPACE
    //Keyboard
    keyboard = lv_keyboard_create(lv_scr_act(), NULL);
    lv_obj_set_size(keyboard,480,300);
    lv_keyboard_set_textarea(keyboard, passcode);
    lv_keyboard_set_mode(keyboard, LV_KEYBOARD_MODE_NUM);
    lv_keyboard_set_map(keyboard, LV_KEYBOARD_MODE_NUM, kb_map);
    lv_keyboard_set_cursor_manage(keyboard, true);
    lv_obj_align(keyboard, NULL, LV_ALIGN_IN_BOTTOM_MID, 0, 0);
You should also set lv_btnmatrix_ctrl_t kb_ctrl_map[] at the same time regardly, you’ll figure it out. Check lv_keyboard.c for examples.
Added lv_btnmatrix_ctrl_t kb_ctrl_map[] to keyboard. now 4 and 8 digits are missing.
