Undestanding the logic begind the lv_obj_add_style and the lv_obj_set_style_xxxxx() functions
9.2
Started from GitHub - EDGEMTech/lv_benchmark
I’m creating an HMI where the user can create and delete, as many times he wants, some widgets.
During the creation of the widgets I’m using the function lv_obj_add_style(lv_obj_t * obj, const lv_style_t * style, lv_style_selector_t selector)
to define the styles of the objects.
Searching on the forum I found this topic: Why do frequent calls to lv_obj_add_style() cause the system to crash?
Where @pete-pjb said that the lv_obj_add_style(…) will leak the memory.
Is this sentence steel true with LVGL 9.2?
Do I need to switch to lv_obj_set_style_xxxxx(…) function?
Could you explain how the two functions work?
Thank you in advance.
GS-X
