I’m using LVGL 8.1, and meet below assertion.
tlsf_assert(block_size(block) >= size);
I wonder under what condition that this assertion would happen, and how should I fix/avoid such problem.
v8.1
static block_header_t * block_locate_free(control_t * control, size_t size)
int fl = 0, sl = 0;
block_header_t * block = 0;
if(size) {
mapping_search(size, &fl, &sl);
** mapping_search can futz with the size, so for excessively large sizes it can sometimes wind up
** with indices that are off the end of the block array.
** So, we protect against that here, since this is the only callsite of mapping_search.
** Note that we don't need to check sl, since it comes from a modulo operation that guarantees it's always in range.
if(fl < FL_INDEX_COUNT) {
block = search_suitable_block(control, &fl, &sl);
if(block) {
remove_free_block(control, block, fl, sl);
return block;
Any suggestion is appreciated.
Many Thanks.
