I found this phenomenon in the process of debugging LVGL in an embedded project: if LV_USE_LARGE_COORD in lv_conf.h should be defined as 1, then lv_example_textarea_1 will not work properly. But this phenomenon does not exist in LVGL PC Simulator.
After tracing the code, I found that if the following line in the draw_border function in lv_draw_rect.c
lv_draw_mask_free_param(&mask_rout_param);
is modified into:
if(mask_rout_id != LV_MASK_ID_INV) lv_draw_mask_free_param(&mask_rout_param);
then lv_example_textarea_1 works well.
Maybe this is a bug. I hope LVGL can do better.
