I’m downloading a jpeg/png image from node.js server and saving it to a uint8_t buffer (image_buffer) on in esp32-s3 external RAM. I’d now like to pass this buffer to lv_img_set_src to display it on my LCD, but I keep getting the following core dump error messages:
Guru Meditation Error: Core 0 panic’ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x4210071b PS : 0x00060b30 A0 : 0x8204c19d A1 : 0x3fcf1460
0x4210071b: lv_fs_seek at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/misc/lv_fs.c:247
A2 : 0x00000000 A3 : 0x00000004 A4 : 0x00000000 A5 : 0x3fcf14a6
A6 : 0x000000ee A7 : 0x000000ff A8 : 0x00000001 A9 : 0x00000001
A10 : 0x3fca6298 A11 : 0x00000001 A12 : 0x000005a0 A13 : 0x00000040
A14 : 0xfffffdff A15 : 0x00000026 SAR : 0x00000020 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000004 LBEG : 0x40056fc5 LEND : 0x40056fe7 LCOUNT : 0xffffffff
0x40056fc5: memcpy in ROM
0x40056fe7: memcpy in ROM
Backtrace: 0x42100718:0x3fcf1460 0x4204c19a:0x3fcf1490 0x4204c3c5:0x3fcf14f0 0x4210036a:0x3fcf1510 0x42049c0f:0x3fcf1530 0x42049cb0:0x3fcf1590 0x4204fac9:0x3fcf15b0 0x4204ff6b:0x3fcf1640 0x420ff999:0x3fcf1670 0x4203e90a:0x3fcf1690 0x4203e9f6:0x3fcf16b0 0x42048f16:0x3fcf16f0 0x42048fcd:0x3fcf1730 0x42048f7f:0x3fcf1780 0x42048fcd:0x3fcf17c0 0x42049249:0x3fcf1810 0x4204944a:0x3fcf1830 0x42049511:0x3fcf18a0 0x420496d5:0x3fcf18d0 0x4204988e:0x3fcf18f0 0x4204e5d9:0x3fcf1920 0x4204e68a:0x3fcf1940 0x4200c4fe:0x3fcf1960 0x40386355:0x3fcf1980
0x42100718: lv_fs_seek at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/misc/lv_fs.c:246
0x4204c19a: lv_img_decoder_built_in_line_alpha at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/draw/lv_img_decoder.c:632
0x4204c3c5: lv_img_decoder_built_in_read_line at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/draw/lv_img_decoder.c:497
0x4210036a: lv_img_decoder_read_line at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/draw/lv_img_decoder.c:179 (discriminator 1)
0x42049c0f: decode_and_draw at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/draw/lv_draw_img.c:330
0x42049cb0: lv_draw_img at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/draw/lv_draw_img.c:80
0x4204fac9: draw_img at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/widgets/lv_img.c:670 (discriminator 2)
0x4204ff6b: lv_img_event at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/widgets/lv_img.c:514
0x420ff999: lv_obj_event_base at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_event.c:96
0x4203e90a: event_send_core at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_event.c:452
0x4203e9f6: lv_event_send at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_event.c:74
0x42048f16: lv_obj_redraw at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:148 (discriminator 3)
0x42048fcd: refr_obj at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:970
0x42048f7f: lv_obj_redraw at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:182 (discriminator 3)
0x42049249: refr_obj_and_children at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:854
0x4204944a: refr_area_part at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:789
0x42049511: refr_area at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:649
0x420496d5: refr_invalid_areas at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:616
0x4204988e: _lv_disp_refr_timer at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/core/lv_refr.c:324
0x4204e5d9: lv_timer_exec at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/misc/lv_timer.c:313 (discriminator 2)
0x4204e68a: lv_timer_handler at C:/Users/karun/ePuzzle/ezzle/esp_code/managed_components/lvgl__lvgl/src/misc/lv_timer.c:109
0x4200c4fe: lvgl_port_task at C:/Users/karun/ePuzzle/ezzle/esp_code/main/lvgl_port.c:481
0x40386355: vPortTaskWrapper at C:/Users/karun/ESP/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:162
My lv_conf.h has the following setting for memory:
#define LV_MEM_CUSTOM 1
Also, my sdkconfig has the following memory settings for LVGL:
CONFIG_LV_MEM_CUSTOM=y
CONFIG_LV_MEM_CUSTOM_INCLUDE="stdlib.h"
CONFIG_LV_MEM_BUF_MAX_NUM=16
# CONFIG_LV_MEMCPY_MEMSET_STD is not set
# end of Memory settings
ESP32-S3
8.4
Make the image buffer appear on LCD without getting a core dump. I’m new to LVGL and have limited familiarity with C. Not sure how I need to modify my image_buffer array to make it work correctly with lv_img_set_src.
void display_img(uint8_t *img_buffer, int size){
lv_obj_t *img1 = lv_img_create(lv_scr_act());
lv_img_dsc_t newImg = {
.header.always_zero = 0,
.header.w = 480,
.header.h = 480,
.data_size = size,
.header.cf = LV_IMG_CF_TRUE_COLOR,
.data = img_buffer
lv_img_set_src(img1, &newImg);
if (lvgl_port_lock(-1)) {
lvgl_port_unlock();
//This part of the code works perfectly fine.
main(){
int content_length = esp_http_client_fetch_headers(client);
uint8_t *image_buffer = (uint8_t *)calloc(content_length, sizeof(uint8_t));
do {
resp_length = esp_http_client_read_response(client, output_buffer, MAX_HTTP_OUTPUT_BUFFER);
if (resp_length >= 0) {
memcpy(image_buffer + cum_data_read, output_buffer, resp_length);
cum_data_read += resp_length;
} else {
ESP_LOGE(TAG, "Failed to read response");
while (resp_length > 0);
display_img(image_buffer, content_length);
