Hi! I have a problem with style change. this is how i do it.
- Create a window
- Call function that adds buttons, button action function changes state of relay depending on which button was pressed.
- Constatntly check if the state of relay changed ( relay state can be changed not just manualy but also automaticly).
- If relay state changes call lv_btn_set_style to change button color. in this step program crashes and for the love of god I cannot figure out why. What I am sure of it’s that in the moment when lv_btn_set_style is called CPU restarts.
Thank you very much for your help and feel fre to ask any additional questions.
ESP32, Arduino
Change of button style.
If style is changed in “Manual_Ctrl” function the program does not crash
// Manual control window
void OpenManWin_Event (lv_obj_t * btn, lv_event_t event) {
if (event == LV_EVENT_RELEASED) {
/*Create a window*/
ManualWin = lv_win_create(lv_scr_act(), NULL);
lv_win_set_title(ManualWin, " Manual control");
lv_win_set_style(ManualWin, LV_WIN_STYLE_HEADER, &lv_style_plain_color);
lv_win_set_style(ManualWin, LV_WIN_STYLE_CONTENT, &lv_style_transp_tight);
lv_win_set_btn_size(ManualWin, 40);
/*Add control buttons to the header*/
// Close window button
lv_obj_t * close_btn = lv_win_add_btn(ManualWin, LV_SYMBOL_CLOSE);
lv_obj_set_event_cb(close_btn, lv_win_close_event_cb);
// Set Regime button
lv_obj_t * Regime_bnt = lv_win_add_btn(ManualWin, LV_SYMBOL_PLAY);
lv_obj_set_event_cb(Regime_bnt, Regime_Ctrl);
// Create container
container = lv_cont_create(ManualWin, NULL);
lv_cont_set_fit(container, LV_FIT_FLOOD);
lv_obj_set_style(container, &lv_style_transp);
lv_cont_set_layout(container, LV_LAYOUT_GRID);
// Create Output modules
Add_Manual_Ctrl_Btn (container, OutputModule[KOMPRESSOR], KOMPRESSOR_TR, 0);
Add_Manual_Ctrl_Btn (container, OutputModule[FAN], FAN_TR, 1);
Add_Manual_Ctrl_Btn (container, OutputModule[STIRRER], STIRRER_TR, 2);
Add_Manual_Ctrl_Btn (container, OutputModule[PUMP], PUMP_TR, 3);
Add_Manual_Ctrl_Btn (container, OutputModule[VALVE1], VALVE1_TR, 4);
Add_Manual_Ctrl_Btn (container, OutputModule[VALVE2], VALVE2_TR, 5);
Add_Manual_Ctrl_Btn (container, OutputModule[VALVE3], VALVE3_TR, 6);
Add_Manual_Ctrl_Btn (container, OutputModule[SPARE], SPARE_TR, 7);
// Create Manual control buttons
void Add_Manual_Ctrl_Btn (lv_obj_t *parent, lv_obj_t * btn, char *Btn_txt, uint32_t Btn_id) {
btn = lv_btn_create(parent, NULL);
lv_obj_set_size(btn, 150, 40);
lv_obj_set_user_data(btn, Btn_id);
lv_obj_set_event_cb(btn, Manual_Ctrl);
lv_obj_t * Signal_label;
Signal_label = lv_label_create(btn, NULL);
lv_btn_set_style(Signal_label, LV_LABEL_STYLE_MAIN, &lv_style_plain);
lv_label_set_text(Signal_label, Btn_txt);
lv_obj_align(Signal_label, NULL, LV_ALIGN_CENTER, 0, 0);
lv_btn_set_style(btn, LV_BTN_STYLE_REL, &Style_Plane);
lv_btn_set_style(btn, LV_BTN_STYLE_PR, &Style_Plane);
// Manual control function
void Manual_Ctrl (lv_obj_t * btn, lv_event_t event) {
uint32_t id = lv_obj_get_user_data(btn);
switch (id) {
case 0: db.Relays.Compressor.HMICmd = true;
break;
case 1: db.Relays.Fan.HMICmd = true;
break;
case 2: db.Relays.Stirrer.HMICmd = true;
break;
case 3: db.Relays.Pump.HMICmd = true;
break;
case 4: db.Relays.Valve1.HMICmd = true;
break;
case 5: db.Relays.Valve2.HMICmd = true;
break;
case 6: db.Relays.Valve3.HMICmd = true;
break;
case 7: db.Relays.Spare.HMICmd = true;
break;
// Detect Relay Status change in Manual function window
void DetectRelayStatusChange(void) {
if (db.Relays.Spare.HMIStatus != RelayStatus_Old[SPARE]) {
RelayStatus_Old[SPARE] = db.Relays.Spare.HMIStatus;
RefreshRelayStatus(OutputModule[SPARE], db.Relays.Spare);
// Refresh Relay Status in Manual function window
void RefreshRelayStatus(lv_obj_t * btn, relay_t &Relay) {
if (Relay.XS) {
lv_btn_set_style(btn, LV_BTN_STYLE_REL, &Style_Green);
lv_btn_set_style(btn, LV_BTN_STYLE_PR, &Style_Green);
else {
