I want to add a screen to a existing squareline project, because i allready made many changes in some of the screens. While the new screens appear, some buttons stoped working and i cant find the reason
esp32 wroom
8.3.6
I want to fix the problem with the buttons that stopped working.
I it has have to do with the implementation of the new screens. I added them to ui.h, ui.c, ui.event.c, ui.event.h and C.Makelists.txt. The screens i copied to the screens folder.
This is the simplest screen. The ButtonBlt works, The ImgButtonHomefromDatentransfer doesnt. This button should bring me back to the start page. However it doesnt work on any screen.
#include "../ui.h"
void ui_Datentransfer_screen_init(void)
ui_Datentransfer = lv_obj_create(NULL);
lv_obj_clear_flag( ui_Datentransfer, LV_OBJ_FLAG_SCROLLABLE ); /// Flags
ui_OberleisteDatentransfer = lv_obj_create(ui_Datentransfer);
lv_obj_set_width( ui_OberleisteDatentransfer, lv_pct(100));
lv_obj_set_height( ui_OberleisteDatentransfer, lv_pct(20));
lv_obj_set_align( ui_OberleisteDatentransfer, LV_ALIGN_TOP_MID );
lv_obj_clear_flag( ui_OberleisteDatentransfer, LV_OBJ_FLAG_SCROLLABLE ); /// Flags
lv_obj_set_style_radius(ui_OberleisteDatentransfer, 0, LV_PART_MAIN| LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(ui_OberleisteDatentransfer, lv_color_hex(0x292831), LV_PART_MAIN | LV_STATE_DEFAULT );
lv_obj_set_style_bg_opa(ui_OberleisteDatentransfer, 255, LV_PART_MAIN| LV_STATE_DEFAULT);
lv_obj_set_style_border_width(ui_OberleisteDatentransfer, 0, LV_PART_MAIN| LV_STATE_DEFAULT);
ui_ImgButtonHomefromDatentransfer = lv_btn_create(ui_OberleisteDatentransfer);
//lv_imgbtn_set_src(ui_ImgButtonHomefromDatentransfer, LV_IMGBTN_STATE_RELEASED, NULL, &ui_img_1766186437, NULL);
lv_obj_set_width( ui_ImgButtonHomefromDatentransfer, 20);
lv_obj_set_height( ui_ImgButtonHomefromDatentransfer, 20);
lv_obj_set_x( ui_ImgButtonHomefromDatentransfer, -103 );
lv_obj_set_y( ui_ImgButtonHomefromDatentransfer, 0 );
lv_obj_set_align( ui_ImgButtonHomefromDatentransfer, LV_ALIGN_CENTER );
lv_obj_add_flag(ui_ImgButtonHomefromDatentransfer, LV_OBJ_FLAG_CLICKABLE); // hinzugefügt
lv_obj_add_flag( ui_ImgButtonHomefromDatentransfer, LV_OBJ_FLAG_SCROLL_ON_FOCUS ); /// Flags
lv_obj_clear_flag( ui_ImgButtonHomefromDatentransfer, LV_OBJ_FLAG_SCROLLABLE ); /// Flags
lv_obj_set_style_bg_color(ui_ImgButtonHomefromDatentransfer, lv_color_hex(0x292999), LV_PART_MAIN | LV_STATE_DEFAULT );
lv_obj_set_style_bg_opa(ui_ImgButtonHomefromDatentransfer, 255, LV_PART_MAIN| LV_STATE_DEFAULT);
ui_ImgButtonbackfromDatentransfer = lv_imgbtn_create(ui_OberleisteDatentransfer);
lv_imgbtn_set_src(ui_ImgButtonbackfromDatentransfer, LV_IMGBTN_STATE_RELEASED, NULL, &ui_img_985096273, NULL);
lv_obj_set_width( ui_ImgButtonbackfromDatentransfer, 20);
lv_obj_set_height( ui_ImgButtonbackfromDatentransfer, 20);
lv_obj_set_x( ui_ImgButtonbackfromDatentransfer, -141 );
lv_obj_set_y( ui_ImgButtonbackfromDatentransfer, 0 );
lv_obj_set_align( ui_ImgButtonbackfromDatentransfer, LV_ALIGN_CENTER );
ui_ButtonBLT = lv_btn_create(ui_Datentransfer);
lv_obj_set_width( ui_ButtonBLT, 100);
lv_obj_set_height( ui_ButtonBLT, 50);
lv_obj_set_align( ui_ButtonBLT, LV_ALIGN_CENTER );
lv_obj_add_flag( ui_ButtonBLT, LV_OBJ_FLAG_SCROLL_ON_FOCUS ); /// Flags
lv_obj_clear_flag( ui_ButtonBLT, LV_OBJ_FLAG_SCROLLABLE ); /// Flags
lv_obj_set_style_bg_color(ui_ButtonBLT, lv_color_hex(0x292831), LV_PART_MAIN | LV_STATE_DEFAULT );
lv_obj_set_style_bg_opa(ui_ButtonBLT, 255, LV_PART_MAIN| LV_STATE_DEFAULT);
ui_LabelBLT = lv_label_create(ui_ButtonBLT);
lv_obj_set_width( ui_LabelBLT, LV_SIZE_CONTENT); /// 1
lv_obj_set_height( ui_LabelBLT, LV_SIZE_CONTENT); /// 1
lv_obj_set_align( ui_LabelBLT, LV_ALIGN_CENTER );
lv_label_set_text(ui_LabelBLT,"connect");
lv_obj_add_event_cb(ui_ImgButtonHomefromDatentransfer, ui_event_ImgButtonHomefromDatentransfer, LV_EVENT_ALL, NULL);
lv_obj_add_event_cb(ui_ButtonBLT, ui_event_ButtonBLT, LV_EVENT_ALL, NULL);
The relevant parts of the ui.c file:
// SCREEN: ui_Datentransfer
void ui_Datentransfer_screen_init(void);
lv_obj_t *ui_Datentransfer;
lv_obj_t *ui_OberleisteDatentransfer;
void ui_event_ImgButtonHomefromDatentransfer( lv_event_t * e);
lv_obj_t *ui_ImgButtonHomefromDatentransfer;
lv_obj_t *ui_ImgButtonbackfromDatentransfer;
void ui_event_ButtonBLT( lv_event_t * e);
lv_obj_t *ui_ButtonBLT;
lv_obj_t *ui_LabelBLT;
lv_obj_t *ui____initial_actions0;
void ui_event_ImgButtonHomefromDatentransfer( lv_event_t * e) {
printf("Entered ui_event_ImgButtonHomefromDatentransfer\n");
printf("Event code: %d\n", event_code);
//lv_event_code_t event_code = lv_event_get_code(e);lv_obj_t * target = lv_event_get_target(e); ändern! oben weg
if ( event_code == LV_EVENT_CLICKED) {
printf("pressed");
_ui_screen_change( &ui_Startbildschirm, LV_SCR_LOAD_ANIM_FADE_ON, 500, 0, &ui_Startbildschirm_screen_init);
printf("presseddone");
void ui_event_ButtonBLT( lv_event_t * e) {
connecttoblt( e );
The ImgButtonHomefromDatentransfer isnt triggered at all. I have tried a lot but nothing worked to fix this. Did i forget to change some file?
I would be very thankful for help or any suggestions.
