UI drawn correctly on startup but garbled on update
For instance, lv_example_get_started_4(); draws a slider correctly but it becomes garbled on update. Video here: https://www.youtube.com/watch?v=LU9YAgiciBw
I use LV_USE_GENERIC_MIPI so the flush function is the unmodified flush_cb from lv_lcd_generic_mipi.c.
To create the display, I use: lv_lcd_generic_mipi_create
Of course, in simulator everything works as it should.
Appreciate any ideas…
Could you share more about your display setup and flush_cb implementation?
