I am using lvgl with stm32f469 diso gui is working well. But I am facing issue in USART operation. I had initialized UART but its is not working. Code build with no error but no result
stm32f469 disco
6.12
USART interrupt operation for GPS module
I had tried two uart 4 and 6, face same issue, But if i initialize separately with new cube project USART work fine.
* @file main.c
* @author Ac6
* @version V1.0
* @date 01-December-2013
* @brief Default main function.
/* Includes ------------------------------------------------------------------*/
#include "USER/inc/main.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
UART_HandleTypeDef huart4;
UART_HandleTypeDef huart6;
static void SystemClock_Config(void);
static void MX_USART6_UART_Init(void);
static void Error_Handler(void);
/* Private functions ---------------------------------------------------------*/
int main(void)
HAL_Init();
/* Configure the system clock to 180 MHz */
SystemClock_Config();
/* Add your application code here */
MX_GPIO_Init();
MX_USART6_UART_Init();
tft_init();
touchpad_init();
// HAL_GPIO_TogglePin(LED_STATUS_GPIO_Port, LED_STATUS_Pin);
// menu_splashscreen();
// menu_MachineInfo();
// menu_MainMenu();
while (1)
HAL_UART_Transmit(&huart6, "Hello\n", 6, 1000);
HAL_GPIO_TogglePin(LED_ACTIVE_GPIO_Port, LED_ACTIVE_Pin);
HAL_Delay(500);
// HAL_Delay(1);
// lv_task_handler();
* The system Clock is configured as follow :
* System Clock source = PLL (HSE)
* SYSCLK(Hz) = 180000000
* HCLK(Hz) = 180000000
* AHB Prescaler = 1
* APB1 Prescaler = 4
* APB2 Prescaler = 2
* HSE Frequency(Hz) = 8000000
* PLL_M = 8
* PLL_N = 360
* PLL_P = 2
* PLL_Q = 7
* PLL_R = 6
* VDD(V) = 3.3
* Main regulator output voltage = Scale1 mode
* Flash Latency(WS) = 5
* @param None
* @retval None
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
/* Enable Power Control clock */
__HAL_RCC_PWR_CLK_ENABLE();
/* The voltage scaling allows optimizing the power consumption when the device is
clocked below the maximum system frequency, to update the voltage scaling value
regarding system frequency refer to product datasheet. */
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/* Enable HSE Oscillator and activate PLL with HSE as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
#if defined(USE_STM32469I_DISCO_REVA)
RCC_OscInitStruct.PLL.PLLM = 25;
#else
RCC_OscInitStruct.PLL.PLLM = 8;
#endif /* USE_STM32469I_DISCO_REVA */
RCC_OscInitStruct.PLL.PLLN = 360;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
RCC_OscInitStruct.PLL.PLLR = 6;
if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/* Enable the OverDrive to reach the 180 Mhz Frequency */
if(HAL_PWREx_EnableOverDrive() != HAL_OK)
Error_Handler();
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
Error_Handler();
* @param None
* @retval None
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOG_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOK_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(LED_STATUS_GPIO_Port, LED_STATUS_Pin, GPIO_PIN_SET);
HAL_GPIO_WritePin(LED_ACTIVE_GPIO_Port, LED_ACTIVE_Pin, GPIO_PIN_SET);
/*Configure GPIO pin : LED_STATUS_Pin */
GPIO_InitStruct.Pin = LED_STATUS_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(LED_STATUS_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : LED_ACTIVE_Pin */
GPIO_InitStruct.Pin = LED_ACTIVE_Pin;
HAL_GPIO_Init(LED_ACTIVE_GPIO_Port, &GPIO_InitStruct);
* @brief USART6 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN USART6_Init 0 */
/* USER CODE END USART6_Init 0 */
/* USER CODE BEGIN USART6_Init 1 */
/* USER CODE END USART6_Init 1 */
huart6.Instance = USART6;
huart6.Init.BaudRate = 9600;
huart6.Init.WordLength = UART_WORDLENGTH_8B;
huart6.Init.StopBits = UART_STOPBITS_1;
huart6.Init.Parity = UART_PARITY_NONE;
huart6.Init.Mode = UART_MODE_TX_RX;
huart6.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart6.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart6) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART6_Init 2 */
/* USER CODE END USART6_Init 2 */
* @brief This function is executed in case of error occurrence.
* @param None
* @retval None
/* User may add here some code to deal with this error */
while(1)
HAL_Delay(500);
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* Infinite loop */
while (1)
