I’m working on a project where display and rotary encoder are used for some settings then they are no more used for weeks, so I need to completely turn off display then encoder push button is reprogrammed to wake up the display
STM32F103 / KEIL
deinit littlevgl or at least unregister display and input encoder then reinit drivers
The feature @kisvegabor mentioned should allow you to do this more easily, but in the meantime, the easiest solution I can think of is to just stop calling lv_task_handler when you want to turn off the display. Be sure to reinitialize the display before running lv_task_handler again.
