Trying to display multiple + signs on CYD
Need Arduino function to generate “+” signs on display
Cheap Yellow Display, ESP32-2432S028, Arduino IDE 2.3.2
9.1
I’m attempting to write an Arduino function that can be called multiple times with coordinates and size of a “+” sign, and will store the various horizontal and vertical components of the “+” signs in an array of line objects.
I’ve written one version of the function that creates six separate line objects (three for vertical lines, three for horizontal lines) for three “+” signs. That seems to work. Now I’m hoping to create an Arduino function I can call that will create an array of line objects for four (as a starting point) “+” signs.
void lv_draw_cross(int cross_nr, lv_point_precise_t center, long int len_pixels) {
    static lv_obj_t *lines[8];
    lv_point_precise_t point, h_line[2], v_line[2];
    // Calculate points for horizontal line
    point.x = center.x - len_pixels / 2;
    point.y = center.y;
    h_line[0] = point;
    point.x = center.x + len_pixels / 2;
    h_line[1] = point;
    // Calculate points for vertical line
    point.x = center.x;
    point.y = center.y - len_pixels / 2;
    v_line[0] = point;
    point.y = center.y + len_pixels / 2;
    v_line[1] = point;
    // Create style
    static lv_style_t style_line;
    lv_style_init(&style_line);
    lv_style_set_line_width(&style_line, 2);
    lv_style_set_line_color(&style_line, lv_palette_main(LV_PALETTE_BLUE));
    lv_style_set_line_rounded(&style_line, true);
    // Create and style horizontal line
    lines[cross_nr * 2] = lv_line_create(lv_scr_act());
    lv_line_set_points(lines[cross_nr * 2], h_line, 2);
    lv_obj_add_style(lines[cross_nr * 2], &style_line, 0);
    // Create and style vertical line
    lines[cross_nr * 2 + 1] = lv_line_create(lv_scr_act());
    lv_line_set_points(lines[cross_nr * 2 + 1], v_line, 2);
    lv_obj_add_style(lines[cross_nr * 2 + 1], &style_line, 0);
I call the function like so:
  lv_point_precise_t center1 = {80, 60};
  lv_point_precise_t center2 = {240, 60};
  lv_point_precise_t center3 = {80, 160};
  lv_point_precise_t center4 = {240, 160};
  lv_draw_cross(0, center1, 20);
  lv_draw_cross(1, center2, 40);
  lv_draw_cross(2, center3, 40);
  lv_draw_cross(2, center3, 20);
This is what I get.
