Hi everyone!
I’ve been trying to create a simple line meter in LVGL 8.3.4. I followed the documentation and read through the library code however, I’ve been trying for a few days now. Can someone please point out what am I doing wrong?
This is a simple line meter in v7.0, which doesn’t work in V8.3 as the functions have been changed.
This is what I have so far just the ticks, can’t figure out how to use the indicator)
Here’s the LVGL code snippet:
void lv_example_meter_1(void)
meter = lv_meter_create(lv_scr_act());
lv_obj_center(meter);
lv_obj_set_size(meter, 235, 235);
/*Add a scale first*/
lv_meter_scale_t * scale = lv_meter_add_scale(meter);
lv_meter_set_scale_ticks(meter, scale, 36, 4, 20, lv_palette_main(LV_PALETTE_GREY));
// remove the center dot
lv_obj_remove_style(meter, NULL, LV_PART_INDICATOR);
lv_meter_indicator_t * indic;
indic = lv_meter_add_scale_lines(meter, scale, lv_palette_main(LV_PALETTE_PURPLE),
lv_palette_main(LV_PALETTE_BLUE), true, 20);
lv_meter_set_indicator_start_value(meter, indic, 0);
lv_meter_set_indicator_start_value(meter, indic, 20);
And here’s the entire code:
#include <lvgl.h>
#define GFX_BL 21 // default backlight pin, you may replace DF_GFX_BL to actual backlight pin
/* More dev device declaration: https://github.com/moononournation/Arduino_GFX/wiki/Dev-Device-Declaration */
#if defined(DISPLAY_DEV_KIT)
Arduino_GFX *gfx = create_default_Arduino_GFX();
#else /* !defined(DISPLAY_DEV_KIT) */
/* More data bus class: https://github.com/moononournation/Arduino_GFX/wiki/Data-Bus-Class */
Arduino_DataBus *bus = create_default_Arduino_DataBus();
/* More display class: https://github.com/moononournation/Arduino_GFX/wiki/Display-Class */
Arduino_GFX *gfx = new Arduino_GC9A01(
bus, 7 /* RST */, 1 /* rotation */, true /* IPS */);
#endif /* !defined(DISPLAY_DEV_KIT) */
* End of Arduino_GFX setting
/* Change to your screen resolution */
static uint32_t screenWidth;
static uint32_t screenHeight;
static lv_color_t *disp_draw_buf;
/* Display flushing */
#if (LV_COLOR_16_SWAP != 0)
gfx->draw16bitBeRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
#else
gfx->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)&color_p->full, w, h);
lv_disp_flush_ready(disp);
/* CUSTOM LVGL FUNCTIONS*/
static lv_obj_t * meter;
// static void set_value(void * indic, int32_t v)
// lv_meter_set_indicator_value(meter, indic, v);
* A simple meter
void setup()
Serial.begin(115200);
// Serial.setDebugOutput(true);
// while(!Serial);
Serial.println("LVGL Hello World Demo");
#ifdef GFX_EXTRA_PRE_INIT
GFX_EXTRA_PRE_INIT();
// Init Display
gfx->begin();
gfx->fillScreen(BLACK);
#ifdef GFX_BL
pinMode(GFX_BL, OUTPUT);
digitalWrite(GFX_BL, HIGH);
screenWidth = gfx->width();
screenHeight = gfx->height();
#ifdef ESP32
disp_draw_buf = (lv_color_t *)heap_caps_malloc(sizeof(lv_color_t) * screenWidth * 32, MALLOC_CAP_INTERNAL | MALLOC_CAP_8BIT);
#else
disp_draw_buf = (lv_color_t *)malloc(sizeof(lv_color_t) * screenWidth * 32);
if (!disp_draw_buf)
Serial.println("LVGL disp_draw_buf allocate failed!");
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * 32);
/* Initialize the display */
lv_disp_drv_init(&disp_drv);
/* Change the following line to your display resolution */
/* Initialize the (dummy) input device driver */
lv_example_meter_1();
void loop()
delay(5);
Any help is really appreciated!
