Try to show image from SD , but failed to allocate dynamic memmory
I try to show image from SD , but failed to allocate dynamic memmory. it neeeds to allocate dynamic memmory to store the image(the size of the image is 9 k),no matter how much I increase the memory, it always prompts " lv_fs_read_cached: Asserted at expression: file_p->cache->buffer != NULL (Out of memory) lv_fs.c:228"
ESP32 s3
9.1
Show image from SD card
I’ve tried to increase the memory in the lv_conf.h or change a smaller image ,but it doesn’t work
here is my lv_conf.h
#if LV_USE_STDLIB_MALLOC == LV_STDLIB_BUILTIN
    /*Size of the memory available for `lv_malloc()` in bytes (>= 2kB)*/
    //#define LV_MEM_SIZE (16 * 1024U)          /*[bytes]*/
    #define LV_MEM_SIZE (32 * 1024U)          /*[bytes]*/
    //#define LV_MEM_SIZE (64 * 1024U)          /*[bytes]*/
    //#define LV_MEM_SIZE (128 * 1024U)          /*[bytes]*/
    /*Size of the memory expand for `lv_malloc()` in bytes*/
    #define LV_MEM_POOL_EXPAND_SIZE 0
    #define LV_MEM_ADR 0     /*0: unused*/
    #if LV_MEM_ADR == 0
        #undef LV_MEM_POOL_INCLUDE
        #undef LV_MEM_POOL_ALLOC
#endif  /*LV_USE_STDLIB_MALLOC == LV_STDLIB_BUILTIN*/
#define LV_USE_FS_FATFS 1
#if LV_USE_FS_FATFS
    #define LV_FS_FATFS_LETTER 'S'     /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
    //#define LV_FS_FATFS_CACHE_SIZE  1024*12    /*>0 to cache this number of bytes in lv_fs_read()*/
    //#define LV_FS_FATFS_CACHE_SIZE  1024*24    /*>0 to cache this number of bytes in lv_fs_read()*/
    #define LV_FS_FATFS_CACHE_SIZE  1024*48    /*>0 to cache this number of bytes in lv_fs_read()*/
here is my test code
void setup()
  Serial.begin(115200);
  SPIClass spi = SPIClass(HSPI);
  spi.begin(40 /* SCK */, 39 /* MISO */, 41 /* MOSI */, 42 /* SS */);
  if (!SD.begin(42 /* SS */, spi, 80000000)) {
    Serial.println("Card Mount Failed");
    return;
  else Serial.println("Card Mount Success");
  pinMode(5, OUTPUT);
  //wifi_int();
  GT911_init();
  lvgl_init();
//  lv_fs_file_t f;
//  lv_fs_res_t res;
//  res = lv_fs_open(&f, "S:hello.txt", LV_FS_MODE_RD);
//  if (res != LV_FS_RES_OK) {
//    Serial.println("Open fail");
//  else {
//    Serial.println("Open OK");
//    uint32_t read_num;
//    uint8_t buf[6];
//    res = lv_fs_read(&f, buf, 6, &read_num);
//    Serial.printf("read:%s", buf);
//    lv_fs_close(&f);
    lv_obj_t *img_bg = lv_img_create(lv_scr_act());
    lv_img_set_src(img_bg, "S:/3.png");
    lv_obj_center(img_bg);
  //main_desk();
the EEROR
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0xb (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a80
entry 0x403c98d0
Card Mount Success
[Error] (0.882, +882) lv_fs_read_cached: Asserted at expression: file_p->cache->buffer != NULL (Out of memory) lv_fs.c:228
Is 9k a size of png-file ? What is the image resolution in png file? You should take into account that to unpack png-file you will need at least RAM:
  1. to store file content - in your case, as far as i understand - 9k
  2. to store unpacked image = Height * Width * 4 - so if your image is 128x128 you need 64k
    So the 32k you allocated may not be enough.
Thank you for your reply!
I realized that I was using a png format image, and the configuration of memory should be considered after decoding. I’m using a 256×256 resolution image, RGB565, which is about 130k.
So I configured the memory again to 160k and still the same error happens. :cry:
what about bmp-files ?
such image files do not require unpacking, so less memory is required
