Trouble understanding profiler output
I’m chasing a performance bottleneck. Ive profiled the code using the internal profiler but have difficulties understanding what causes the bottleneck.
STMH7 + SDRAM running ChibiOS RTOS
GCC
Current master
Understand the profiller output
All optimization steps like correct compiler flags, reduce heavy features like gradients / transparency.
Profiller output inside the 7z archive. The output contains 5 sections when the code is running. The 3 minute gaps are most likely caused by flushing a 20MB interal buffer containing the trace output.
