Touchscreen is ok and can print coordinate,but no responds when click the button
Important: my board is linux system ,use the samsung screen and gslx680 touch ic. LVGL9.0
imx6ull
LVGL9.0.0
my button can capture the touch event
my touchscreen can print the touch coordinate
  • Linux frame buffer device (/dev/fbx)
    #ifndef USE_FBDEV
define USE_FBDEV 1
#if USE_FBDEV
define FBDEV_PATH “/dev/fb0”
  • FreeBSD frame buffer device (/dev/fbx)
    #ifndef USE_BSD_FBDEV
define USE_BSD_FBDEV 0
#if USE_BSD_FBDEV
  • DRM/KMS device (/dev/dri/cardX)
    #ifndef USE_DRM
define USE_DRM 0
#if USE_DRM
define DRM_CARD “/dev/dri/card0”
define DRM_CONNECTOR_ID -1 /* -1 for the first connected one */
  • INPUT DEVICES
  • XPT2046
    #ifndef USE_XPT2046
define USE_XPT2046 0
#if USE_XPT2046
define XPT2046_HOR_RES 480
define XPT2046_VER_RES 320
define XPT2046_X_MIN 200
define XPT2046_Y_MIN 200
define XPT2046_X_MAX 3800
define XPT2046_Y_MAX 3800
define XPT2046_AVG 4
define XPT2046_X_INV 0
define XPT2046_Y_INV 0
define XPT2046_XY_SWAP 0
  • FT5406EE8
    #ifndef USE_FT5406EE8
define USE_FT5406EE8 0
#if USE_FT5406EE8
define FT5406EE8_I2C_ADR 0x38 /7 bit address/
  • AD TOUCH
    #ifndef USE_AD_TOUCH
define USE_AD_TOUCH 0
#if USE_AD_TOUCH
/No settings/
  • Mouse or touchpad on PC (using SDL)
    /*DEPRECATED: Use the SDL driver instead. */
    #ifndef USE_MOUSE
define USE_MOUSE 0
#if USE_MOUSE
/No settings/
  • Mousewheel as encoder on PC (using SDL)
    #ifndef USE_MOUSEWHEEL
define USE_MOUSEWHEEL 0
#if USE_MOUSEWHEEL
/No settings/
#if 0
  • Touchscreen, mouse/touchpad or keyboard as libinput interface (for Linux based systems)
    #ifndef USE_LIBINPUT
define USE_LIBINPUT 0
#ifndef USE_BSD_LIBINPUT
define USE_BSD_LIBINPUT 0
#if USE_LIBINPUT || USE_BSD_LIBINPUT
/*If only a single device of the same type is connected, you can also auto detect it, e.g.:
#define LIBINPUT_NAME libinput_find_dev(LIBINPUT_CAPABILITY_TOUCH, false)/
define LIBINPUT_NAME “/dev/input/event0” /You can use the “evtest” Linux tool to get the list of devices and test them/
#endif /USE_LIBINPUT || USE_BSD_LIBINPUT/
  • Mouse or touchpad as evdev interface (for Linux based systems)
    #ifndef USE_EVDEV
define USE_EVDEV 1
#ifndef USE_BSD_EVDEV
define USE_BSD_EVDEV 0
#if USE_EVDEV || USE_BSD_EVDEV
define EVDEV_NAME “/dev/input/event0” /You can use the “evtest” Linux tool to get the list of devices and test them/
define EVDEV_SWAP_AXES 1 /Swap the x and y axes of the touchscreen/
define EVDEV_CALIBRATE 1 /Scale and offset the touchscreen coordinates by using maximum and minimum values for each axis/
if EVDEV_CALIBRATE
define EVDEV_HOR_MIN 0 /to invert axis swap EVDEV_XXX_MIN by EVDEV_XXX_MAX/
define EVDEV_HOR_MAX 1280 /“evtest” Linux tool can help to get the correct calibraion values>/
define EVDEV_VER_MIN 0
define EVDEV_VER_MAX 800
endif /EVDEV_CALIBRATE/
#endif /USE_EVDEV/
int main(void)
/LittlevGL init/
/*Linux frame buffer device init*/
fbdev_init();
/*A small buffer for LittlevGL to draw the screen's content*/
static lv_color_t buf[DISP_BUF_SIZE];
/*Initialize a descriptor for the buffer*/
lv_disp_draw_buf_init(&disp_buf, buf, NULL, DISP_BUF_SIZE);
/*Initialize and register a display driver*/
static lv_disp_drv_t disp_drv1;
/*注册屏幕驱动*/
lv_disp_drv_init(&disp_drv1);
disp_drv1.draw_buf	= &disp_buf;
disp_drv1.flush_cb	= fbdev_flush;
disp_drv1.hor_res	= LCD_DISPLAY_WIDTH;
disp_drv1.ver_res	= LCD_DISPLAY_HEIGHT;
disp_drv1.sw_rotate = 2;   // add for rotation
disp_drv1.screen_transp = 1;
disp_drv1.rotated = LV_DISP_ROT_270;
lv_disp_drv_register(&disp_drv1);
lv_obj_set_style_bg_opa(lv_scr_act(), LV_OPA_TRANSP,0);
evdev_init();
lv_indev_drv_t indev_drv_1;
lv_indev_drv_init(&indev_drv_1);
indev_drv_1.type =LV_INDEV_TYPE_POINTER;
indev_drv_1.read_cb =evdev_read;
lv_indev_drv_register(&indev_drv_1);
lv_example_style_back(1);
lv_style_button();
    lvgl_clock_start();
while(1) {
    lv_timer_handler();
    usleep(5000);
return 0;
void lv_style_button(void)
static lv_style_t style_label;
static lv_style_t style_btn;
lv_style_init(&style_btn);
lv_style_init(&style_label);
lv_obj_t * btn1 = lv_btn_create(lv_scr_act());
lv_obj_add_event_cb(btn1, event_handler_1, LV_EVENT_VALUE_CHANGED, NULL);
lv_obj_set_size(btn1, 100, 50);
lv_obj_set_pos(btn1, 200,600);
//lv_obj_align_to(btn1, lv_layer_top(), LV_ALIGN_BOTTOM_LEFT, 0, 0);
lv_style_set_radius(&style_btn,  20);
//lv_style_set_shadow_opa(&style_btn,  LV_OPA_30);
lv_style_set_bg_opa(&style_btn,  255);
lv_obj_add_flag(btn1, LV_OBJ_FLAG_CHECKABLE);
lv_style_set_bg_color( &style_btn, lv_color_white());
lv_obj_add_style(btn1, &style_btn, 0);
static void event_handler_1(lv_event_t * e)
lv_obj_t *sw = lv_event_get_target(e);
    if(code == LV_EVENT_VALUE_CHANGED) {
    if (lv_obj_has_state(sw, LV_STATE_CHECKED))
	printf("IPC ON WORKING\n");
	lv_example_style_back(0);
Touch screen is enable and we r getting coordinates from touchpad_read function but not able click button. Kindly provide any solution of this issue…
