Hello Guys,
I am using the lvgl_demo_widgets example that came with the MCUXpresso IDE and this 7" display from Riverdi. I have designed a bridge from the 40pin to the 50pin required for the RGB and the same for the capacitive touch signals.
I.MXRT1050-EVKB
LVGL 8.0.2
I would like to achieve the touch controls working properly.
I have tried adding the lv_drivers to my project and setting USE_FT5406EE8 to 1 in the lv_drv_conf.h
* FT5406EE8
#ifndef USE_FT5406EE8
# define USE_FT5406EE8 1
lv_drv_conf.h
* COPY THIS FILE AS lv_drv_conf.h
/* clang-format off */
#if 1 /*Set it to "1" to enable the content*/
#ifndef LV_DRV_CONF_H
#define LV_DRV_CONF_H
#include "lv_conf.h"
* DELAY INTERFACE
#define LV_DRV_DELAY_INCLUDE <stdint.h> /*Dummy include by default*/
#define LV_DRV_DELAY_US(us) /*delay_us(us)*/ /*Delay the given number of microseconds*/
#define LV_DRV_DELAY_MS(ms) /*delay_ms(ms)*/ /*Delay the given number of milliseconds*/
* DISPLAY INTERFACE
* Common
#define LV_DRV_DISP_INCLUDE <stdint.h> /*Dummy include by default*/
#define LV_DRV_DISP_CMD_DATA(val) /*pin_x_set(val)*/ /*Set the command/data pin to 'val'*/
#define LV_DRV_DISP_RST(val) /*pin_x_set(val)*/ /*Set the reset pin to 'val'*/
* SPI
#define LV_DRV_DISP_SPI_CS(val) /*spi_cs_set(val)*/ /*Set the SPI's Chip select to 'val'*/
#define LV_DRV_DISP_SPI_WR_BYTE(data) /*spi_wr(data)*/ /*Write a byte the SPI bus*/
#define LV_DRV_DISP_SPI_WR_ARRAY(adr, n) /*spi_wr_mem(adr, n)*/ /*Write 'n' bytes to SPI bus from 'adr'*/
* Parallel port
#define LV_DRV_DISP_PAR_CS(val) /*par_cs_set(val)*/ /*Set the Parallel port's Chip select to 'val'*/
#define LV_DRV_DISP_PAR_SLOW /*par_slow()*/ /*Set low speed on the parallel port*/
#define LV_DRV_DISP_PAR_FAST /*par_fast()*/ /*Set high speed on the parallel port*/
#define LV_DRV_DISP_PAR_WR_WORD(data) /*par_wr(data)*/ /*Write a word to the parallel port*/
#define LV_DRV_DISP_PAR_WR_ARRAY(adr, n) /*par_wr_mem(adr,n)*/ /*Write 'n' bytes to Parallel ports from 'adr'*/
* INPUT DEVICE INTERFACE
* Common
#define LV_DRV_INDEV_INCLUDE <stdint.h> /*Dummy include by default*/
#define LV_DRV_INDEV_RST(val) /*pin_x_set(val)*/ /*Set the reset pin to 'val'*/
#define LV_DRV_INDEV_IRQ_READ 0 /*pn_x_read()*/ /*Read the IRQ pin*/
* SPI
#define LV_DRV_INDEV_SPI_CS(val) /*spi_cs_set(val)*/ /*Set the SPI's Chip select to 'val'*/
#define LV_DRV_INDEV_SPI_XCHG_BYTE(data) 0 /*spi_xchg(val)*/ /*Write 'val' to SPI and give the read value*/
* I2C
#define LV_DRV_INDEV_I2C_START /*i2c_start()*/ /*Make an I2C start*/
#define LV_DRV_INDEV_I2C_STOP /*i2c_stop()*/ /*Make an I2C stop*/
#define LV_DRV_INDEV_I2C_RESTART /*i2c_restart()*/ /*Make an I2C restart*/
#define LV_DRV_INDEV_I2C_WR(data) /*i2c_wr(data)*/ /*Write a byte to the I1C bus*/
#define LV_DRV_INDEV_I2C_READ(last_read) 0 /*i2c_rd()*/ /*Read a byte from the I2C bud*/
* DISPLAY DRIVERS
* SDL
/* SDL based drivers for display, mouse, mousewheel and keyboard*/
#ifndef USE_SDL
# define USE_SDL 0
/* Hardware accelerated SDL driver */
#ifndef USE_SDL_GPU
# define USE_SDL_GPU 0
#if USE_SDL || USE_SDL_GPU
# define SDL_HOR_RES 480
# define SDL_VER_RES 320
/* Scale window by this factor (useful when simulating small screens) */
# define SDL_ZOOM 1
/* Used to test true double buffering with only address changing.
* Use 2 draw buffers, bith with SDL_HOR_RES x SDL_VER_RES size*/
# define SDL_DOUBLE_BUFFERED 0
/*Eclipse: <SDL2/SDL.h> Visual Studio: <SDL.h>*/
# define SDL_INCLUDE_PATH <SDL2/SDL.h>
/*Open two windows to test multi display support*/
# define SDL_DUAL_DISPLAY 0
* Monitor of PC
/*DEPRECATED: Use the SDL driver instead. */
#ifndef USE_MONITOR
# define USE_MONITOR 0
#if USE_MONITOR
# define MONITOR_HOR_RES 480
# define MONITOR_VER_RES 320
# define MONITOR_ZOOM 1
* Use 2 draw buffers, bith with MONITOR_HOR_RES x MONITOR_VER_RES size*/
# define MONITOR_DOUBLE_BUFFERED 0
# define MONITOR_SDL_INCLUDE_PATH <SDL2/SDL.h>
# define MONITOR_DUAL 0
* Native Windows (including mouse)
#ifndef USE_WINDOWS
# define USE_WINDOWS 0
#if USE_WINDOWS
# define WINDOW_HOR_RES 480
# define WINDOW_VER_RES 320
* Native Windows (win32drv)
#ifndef USE_WIN32DRV
# define USE_WIN32DRV 0
#if USE_WIN32DRV
# define WIN32DRV_MONITOR_ZOOM 1
* GTK drivers (monitor, mouse, keyboard
#ifndef USE_GTK
# define USE_GTK 0
* Wayland drivers (monitor, mouse, keyboard, touchscreen)
#ifndef USE_WAYLAND
# define USE_WAYLAND 0
#if USE_WAYLAND
/* Support for client-side decorations */
# ifndef LV_WAYLAND_CLIENT_SIDE_DECORATIONS
# define LV_WAYLAND_CLIENT_SIDE_DECORATIONS 1
# endif
/* Support for (deprecated) wl-shell protocol */
# ifndef LV_WAYLAND_WL_SHELL
# define LV_WAYLAND_WL_SHELL 1
# endif
/* Support for xdg-shell protocol */
# ifndef LV_WAYLAND_XDG_SHELL
# define LV_WAYLAND_XDG_SHELL 0
# endif
* SSD1963
#ifndef USE_SSD1963
# define USE_SSD1963 0
#if USE_SSD1963
# define SSD1963_HOR_RES LV_HOR_RES
# define SSD1963_VER_RES LV_VER_RES
# define SSD1963_HT 531
# define SSD1963_HPS 43
# define SSD1963_LPS 8
# define SSD1963_HPW 10
# define SSD1963_VT 288
# define SSD1963_VPS 12
# define SSD1963_FPS 4
# define SSD1963_VPW 10
# define SSD1963_HS_NEG 0 /*Negative hsync*/
# define SSD1963_VS_NEG 0 /*Negative vsync*/
# define SSD1963_ORI 0 /*0, 90, 180, 270*/
# define SSD1963_COLOR_DEPTH 16
* R61581
#ifndef USE_R61581
# define USE_R61581 0
#if USE_R61581
# define R61581_HOR_RES LV_HOR_RES
# define R61581_VER_RES LV_VER_RES
# define R61581_HSPL 0 /*HSYNC signal polarity*/
# define R61581_HSL 10 /*HSYNC length (Not Implemented)*/
# define R61581_HFP 10 /*Horitontal Front poarch (Not Implemented)*/
# define R61581_HBP 10 /*Horitontal Back poarch (Not Implemented */
# define R61581_VSPL 0 /*VSYNC signal polarity*/
# define R61581_VSL 10 /*VSYNC length (Not Implemented)*/
# define R61581_VFP 8 /*Vertical Front poarch*/
# define R61581_VBP 8 /*Vertical Back poarch */
# define R61581_DPL 0 /*DCLK signal polarity*/
# define R61581_EPL 1 /*ENABLE signal polarity*/
# define R61581_ORI 0 /*0, 180*/
# define R61581_LV_COLOR_DEPTH 16 /*Fix 16 bit*/
* ST7565 (Monochrome, low res.)
#ifndef USE_ST7565
# define USE_ST7565 0
#if USE_ST7565
/*No settings*/
#endif /*USE_ST7565*/
* GC9A01 (color, low res.)
#ifndef USE_GC9A01
# define USE_GC9A01 0
#if USE_GC9A01
/*No settings*/
#endif /*USE_GC9A01*/
* UC1610 (4 gray 160*[104|128])
* (EA DOGXL160 160x104 tested)
#ifndef USE_UC1610
# define USE_UC1610 0
#if USE_UC1610
# define UC1610_HOR_RES LV_HOR_RES
# define UC1610_VER_RES LV_VER_RES
# define UC1610_INIT_CONTRAST 33 /* init contrast, values in [%] */
# define UC1610_INIT_HARD_RST 0 /* 1 : hardware reset at init, 0 : software reset */
# define UC1610_TOP_VIEW 0 /* 0 : Bottom View, 1 : Top View */
#endif /*USE_UC1610*/
* SHARP memory in pixel monochrome display series
* LS012B7DD01 (184x38 pixels.)
* LS013B7DH03 (128x128 pixels.)
* LS013B7DH05 (144x168 pixels.)
* LS027B7DH01 (400x240 pixels.) (tested)
* LS032B7DD02 (336x536 pixels.)
* LS044Q7DH01 (320x240 pixels.)
#ifndef USE_SHARP_MIP
# define USE_SHARP_MIP 0
#if USE_SHARP_MIP
# define SHARP_MIP_HOR_RES LV_HOR_RES
# define SHARP_MIP_VER_RES LV_VER_RES
# define SHARP_MIP_SOFT_COM_INVERSION 0
# define SHARP_MIP_REV_BYTE(b) /*((uint8_t) __REV(__RBIT(b)))*/ /*Architecture / compiler dependent byte bits order reverse*/
#endif /*USE_SHARP_MIP*/
* ILI9341 240X320 TFT LCD
#ifndef USE_ILI9341
# define USE_ILI9341 0
#if USE_ILI9341
# define ILI9341_HOR_RES LV_HOR_RES
# define ILI9341_VER_RES LV_VER_RES
# define ILI9341_GAMMA 1
# define ILI9341_TEARING 0
#endif /*USE_ILI9341*/
* Linux frame buffer device (/dev/fbx)
#ifndef USE_FBDEV
# define USE_FBDEV 0
#if USE_FBDEV
# define FBDEV_PATH "/dev/fb0"
* FreeBSD frame buffer device (/dev/fbx)
#ifndef USE_BSD_FBDEV
# define USE_BSD_FBDEV 0
#if USE_BSD_FBDEV
* DRM/KMS device (/dev/dri/cardX)
#ifndef USE_DRM
# define USE_DRM 0
#if USE_DRM
# define DRM_CARD "/dev/dri/card0"
# define DRM_CONNECTOR_ID -1 /* -1 for the first connected one */
* INPUT DEVICES
* XPT2046
#ifndef USE_XPT2046
# define USE_XPT2046 0
#if USE_XPT2046
# define XPT2046_HOR_RES 480
# define XPT2046_VER_RES 320
# define XPT2046_X_MIN 200
# define XPT2046_Y_MIN 200
# define XPT2046_X_MAX 3800
# define XPT2046_Y_MAX 3800
# define XPT2046_AVG 4
# define XPT2046_X_INV 0
# define XPT2046_Y_INV 0
# define XPT2046_XY_SWAP 0
* FT5406EE8
#if USE_FT5406EE8
# define FT5406EE8_I2C_ADR 0x38 /*7 bit address*/
* AD TOUCH
#ifndef USE_AD_TOUCH
# define USE_AD_TOUCH 0
#if USE_AD_TOUCH
/*No settings*/
* Mouse or touchpad on PC (using SDL)
#ifndef USE_MOUSE
# define USE_MOUSE 0
#if USE_MOUSE
/*No settings*/
* Mousewheel as encoder on PC (using SDL)
#ifndef USE_MOUSEWHEEL
# define USE_MOUSEWHEEL 0
#if USE_MOUSEWHEEL
/*No settings*/
* Touchscreen, mouse/touchpad or keyboard as libinput interface (for Linux based systems)
#ifndef USE_LIBINPUT
# define USE_LIBINPUT 0
#ifndef USE_BSD_LIBINPUT
# define USE_BSD_LIBINPUT 0
#if USE_LIBINPUT || USE_BSD_LIBINPUT
/*If only a single device of the same type is connected, you can also auto detect it, e.g.:
*#define LIBINPUT_NAME libinput_find_dev(LIBINPUT_CAPABILITY_TOUCH, false)*/
# define LIBINPUT_NAME "/dev/input/event0" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
#endif /*USE_LIBINPUT || USE_BSD_LIBINPUT*/
* Mouse or touchpad as evdev interface (for Linux based systems)
#ifndef USE_EVDEV
# define USE_EVDEV 0
#ifndef USE_BSD_EVDEV
# define USE_BSD_EVDEV 0
#if USE_EVDEV || USE_BSD_EVDEV
# define EVDEV_NAME "/dev/input/event0" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
# define EVDEV_SWAP_AXES 0 /*Swap the x and y axes of the touchscreen*/
# define EVDEV_CALIBRATE 0 /*Scale and offset the touchscreen coordinates by using maximum and minimum values for each axis*/
# if EVDEV_CALIBRATE
# define EVDEV_HOR_MIN 0 /*to invert axis swap EVDEV_XXX_MIN by EVDEV_XXX_MAX*/
# define EVDEV_HOR_MAX 4096 /*"evtest" Linux tool can help to get the correct calibraion values>*/
# define EVDEV_VER_MIN 0
# define EVDEV_VER_MAX 4096
# endif /*EVDEV_CALIBRATE*/
#endif /*USE_EVDEV*/
* Full keyboard support for evdev and libinput interface
# ifndef USE_XKB
# define USE_XKB 0
# endif
#if USE_LIBINPUT || USE_BSD_LIBINPUT || USE_EVDEV || USE_BSD_EVDEV
# if USE_XKB
# define XKB_KEY_MAP { .rules = NULL, \
.model = "pc101", \
.layout = "us", \
.variant = NULL, \
.options = NULL } /*"setxkbmap -query" can help find the right values for your keyboard*/
# endif /*USE_XKB*/
#endif /*USE_LIBINPUT || USE_BSD_LIBINPUT || USE_EVDEV || USE_BSD_EVDEV*/
* Keyboard of a PC (using SDL)
#ifndef USE_KEYBOARD
# define USE_KEYBOARD 0
#if USE_KEYBOARD
/*No settings*/
#endif /*LV_DRV_CONF_H*/
lvgl_demo_widgets.c
* Copyright 2020 NXP
* All rights reserved.
* SPDX-License-Identifier: BSD-3-Clause
#include "FreeRTOS.h"
#include "task.h"
#include "fsl_debug_console.h"
#include "lvgl_support.h"
#include "pin_mux.h"
#include "board.h"
#include "lvgl.h"
#include "lv_examples/src/lv_demo_widgets/lv_demo_widgets.h"
* Definitions
static volatile bool s_lvgl_initialized = false;
* Prototypes
#if LV_USE_LOG
static void print_cb(lv_log_level_t level, const char *file, uint32_t line, const char *func, const char *buf)
/*Use only the file name not the path*/
size_t p;
for (p = strlen(file); p > 0; p--)
if (file[p] == '/' || file[p] == '\\')
p++; /*Skip the slash*/
break;
static const char *lvl_prefix[] = {"Trace", "Info", "Warn", "Error", "User"};
PRINTF("\r%s: %s \t(%s #%d %s())\n", lvl_prefix[level], buf, &file[p], line, func);
static void AppTask(void *param)
#if LV_USE_LOG
lv_log_register_print_cb(print_cb);
PRINTF("lvgl widgets demo started\r\n");
lv_port_pre_init();
lv_port_disp_init();
lv_port_indev_init();
s_lvgl_initialized = true;
lv_demo_widgets();
for (;;)
lv_task_handler();
vTaskDelay(5);
* Code
AT_QUICKACCESS_SECTION_CODE(void BOARD_ReconfigFlexSpiRxBuffer(void));
* When PXP fetch images from FlexSPI flash, the default FlexSPI RX buffer
* configuration does not meet the PXP bandwidth requirement. Reconfigure
* here.
uint32_t ahbcr;
/* Disable I cache and D cache */
if (SCB_CCR_IC_Msk == (SCB_CCR_IC_Msk & SCB->CCR))
SCB_DisableICache();
if (SCB_CCR_DC_Msk == (SCB_CCR_DC_Msk & SCB->CCR))
SCB_DisableDCache();
ahbcr = FLEXSPI->AHBCR;
/* Temporarily disable prefetching while changing the buffer settings */
FLEXSPI->AHBCR = ahbcr & ~(FLEXSPI_AHBCR_CACHABLEEN_MASK | FLEXSPI_AHBCR_PREFETCHEN_MASK);
/* Wait for FlexSPI idle to make sure no flash data transfer. */
while ((FLEXSPI->STS0 & FLEXSPI_STS0_ARBIDLE_MASK) == 0U)
/* Allocate half of the prefetch buffer to the core */
FLEXSPI->AHBRXBUFCR0[0] =
FLEXSPI_AHBRXBUFCR0_PREFETCHEN_MASK | FLEXSPI_AHBRXBUFCR0_MSTRID(0) | FLEXSPI_AHBRXBUFCR0_BUFSZ(0x40);
/* Disable dedicate prefetch buffer for DMA. */
FLEXSPI->AHBRXBUFCR0[1] =
FLEXSPI_AHBRXBUFCR0_PREFETCHEN_MASK | FLEXSPI_AHBRXBUFCR0_MSTRID(1) | FLEXSPI_AHBRXBUFCR0_BUFSZ(0x00);
/* Disable dedicate prefetch buffer for DCP. */
FLEXSPI->AHBRXBUFCR0[2] =
FLEXSPI_AHBRXBUFCR0_PREFETCHEN_MASK | FLEXSPI_AHBRXBUFCR0_MSTRID(2) | FLEXSPI_AHBRXBUFCR0_BUFSZ(0x00);
/* Other half of the buffer for other masters incl. PXP */
FLEXSPI->AHBRXBUFCR0[3] =
FLEXSPI_AHBRXBUFCR0_PREFETCHEN_MASK | FLEXSPI_AHBRXBUFCR0_MSTRID(3) | FLEXSPI_AHBRXBUFCR0_BUFSZ(0x40);
FLEXSPI->AHBCR = ahbcr; /* Set AHBCR back to the original value */
/* Enable I cache and D cache */
SCB_EnableDCache();
SCB_EnableICache();
* @brief Main function
int main(void)
BaseType_t stat;
/* Init board hardware. */
/* Set the eLCDIF read_qos priority high, to make sure eLCDIF
* can fetch data in time when PXP is used.
*((volatile uint32_t *)0x41044100) = 5;
BOARD_ConfigMPU();
BOARD_ReconfigFlexSpiRxBuffer();
BOARD_InitPins();
BOARD_InitI2C1Pins();
BOARD_InitSemcPins();
BOARD_BootClockRUN();
BOARD_InitDebugConsole();
stat = xTaskCreate(AppTask, "lvgl", configMINIMAL_STACK_SIZE + 800, NULL, tskIDLE_PRIORITY + 2, NULL);
if (pdPASS != stat)
PRINTF("Failed to create lvgl task");
while (1)
vTaskStartScheduler();
for (;;)
} /* should never get here */
* @brief Malloc failed hook.
void vApplicationMallocFailedHook(void)
for (;;)
* @brief FreeRTOS tick hook.
void vApplicationTickHook(void)
if (s_lvgl_initialized)
lv_tick_inc(1);
* @brief Stack overflow hook.
void vApplicationStackOverflowHook(TaskHandle_t xTask, char *pcTaskName)
(void)pcTaskName;
(void)xTask;
for (;;)
Video of behavior.
