I can get my touch driver working, but button presses are not registering.
ESP32 with parallel ILI9488 and FT6236 (ESP32-S2 Parallel TFT with Touch 3.5'' ILI9488 V1.1 | Makerfabs). Latest Arduino IDE, lvgl 8.2.
Getting button presses registering.
I tried different touchscreen drivers (lovyangfx, dustinwatts ft6236 driver, makerfabs own driver), but these are not working. “my_touchpad_read” never gets called. I added Serial.println(“mytouchpadread was called”); but I never see it in the serial console. I do see however output like this in the console: “Screen was touched at x 35 and y 134” due to the test routine
I added to the loop.
#define LGFX_USE_V1
#include <LovyanGFX.hpp>
#include <SPI.h>
#include <lvgl.h>
#include <FT6236.h>
#include <WiFi.h>
const char* ssid = "MySSID";
const char* password = "VerySecret";
//#define SDA_FT6236 38
//#define SCL_FT6236 39
//FT6236 ts = FT6236();
//#define I2C_SCL 39
//#define I2C_SDA 38
#define LCD_CS 37
#define LCD_BLK 45
class LGFX : public lgfx::LGFX_Device
//lgfx::Panel_ILI9341 _panel_instance;
lgfx::Panel_ILI9488 _panel_instance;
lgfx::Bus_Parallel16 _bus_instance;
lgfx::Touch_FT5x06 _touch_instance;
public:
LGFX(void)
auto cfg = _bus_instance.config();
// 16位设置
cfg.i2s_port = I2S_NUM_0;
cfg.freq_write = 16000000;
cfg.pin_wr = 35;
cfg.pin_rd = 34;
cfg.pin_rs = 36;
cfg.pin_d0 = 33;
cfg.pin_d1 = 21;
cfg.pin_d2 = 14;
cfg.pin_d3 = 13;
cfg.pin_d4 = 12;
cfg.pin_d5 = 11;
cfg.pin_d6 = 10;
cfg.pin_d7 = 9;
cfg.pin_d8 = 3;
cfg.pin_d9 = 8;
cfg.pin_d10 = 16;
cfg.pin_d11 = 15;
cfg.pin_d12 = 7;
cfg.pin_d13 = 6;
cfg.pin_d14 = 5;
cfg.pin_d15 = 4;
_bus_instance.config(cfg);
_panel_instance.setBus(&_bus_instance);
auto cfg = _panel_instance.config();
cfg.pin_cs = -1;
cfg.pin_rst = -1;
cfg.pin_busy = -1;
cfg.memory_width = 320;
cfg.memory_height = 480;
cfg.panel_width = 320;
cfg.panel_height = 480;
cfg.offset_x = 0;
cfg.offset_y = 0;
cfg.offset_rotation = 0;
cfg.dummy_read_pixel = 8;
cfg.dummy_read_bits = 1;
cfg.readable = true;
cfg.invert = false;
cfg.rgb_order = false;
cfg.dlen_16bit = true;
cfg.bus_shared = true;
_panel_instance.config(cfg);
auto cfg = _touch_instance.config();
cfg.x_min = 0;
cfg.x_max = 319;
cfg.y_min = 0;
cfg.y_max = 479;
cfg.pin_int = -1;
cfg.bus_shared = false;
cfg.i2c_port = 0;
cfg.i2c_addr = 0x38;
cfg.pin_sda = 38;
cfg.pin_scl = 39;
cfg.freq = 400000;
_touch_instance.config(cfg);
_panel_instance.setTouch(&_touch_instance);
setPanel(&_panel_instance);
LGFX tft;
static const uint32_t screenWidth = 320;
static const uint32_t screenHeight = 480;
static lv_color_t buf[ screenWidth * 10 ];
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
//tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.writePixels((lgfx::rgb565_t *)&color_p->full, w * h);
//tft.writePixels((lgfx::swap565_t*)&color_p->full, w*h);
tft.endWrite();
lv_disp_flush_ready( disp );
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
Serial.println("mytouchpadread was called");
uint16_t touchX, touchY;
bool touched =tft.getTouch(&touchX, &touchY);
if(!touched)
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
Serial.print( "Data x " );
Serial.println( touchX );
Serial.print( "Data y " );
Serial.println( touchY );
void setup(void)
pinMode(LCD_CS, OUTPUT);
pinMode(LCD_BLK, OUTPUT);
digitalWrite(LCD_CS, LOW);
digitalWrite(LCD_BLK, HIGH);
Serial.begin(115200);
// Connect to WiFi network
WiFi.begin(ssid, password);
Serial.println("");
// Wait for connection
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println(WiFi.localIP());
tft.init();
// tft.setRotation(1);
tft.setBrightness(120);
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * 10 );
//Initialize the display
lv_disp_drv_init(&disp_drv);
//Change the following line to your display resolution
lv_example_get_started_1();
void loop()
if(touched)
Serial.print("Screen was touched at x "); Serial.print(touchX) ; Serial.print(" and y "); Serial.println(touchY);
lv_timer_handler();
delay( 5 );
static void btn_event_cb(lv_event_t * e)
// Serial.print(code); Serial.print(" "); Serial.println(LV_EVENT_CLICKED);
lv_obj_t * btn = lv_event_get_target(e);
static uint8_t cnt = 0;
cnt++;
/*Get the first child of the button which is the label and change its text*/
lv_obj_t * label = lv_obj_get_child(btn, 0);
lv_label_set_text_fmt(label, "Button: %d", cnt);
void lv_example_get_started_1(void)
lv_obj_t * btn = lv_btn_create(lv_scr_act());
lv_obj_set_size(btn, 120, 50);
lv_obj_align(btn, LV_ALIGN_CENTER, 0,0);
lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_ALL, NULL);
lv_obj_t * label = lv_label_create(btn);
lv_obj_center(label);
```c
