I am having issues with a bacis interface that has 2 screens with 1 button each. When PRESSED Button1 on Screen1 should switch Screen1 to Screen 2. The event1 on button1 is triggered by pressed. The action is set to Change Screen and the Screen to set to Screen2. Everyting in the simulator works as expected. Program Uploads on on a Arduino Nano ESP32 however when pressing the button on the screen the screen does not change and the serial monitor records a SINGLE CLICK, but swipeing left or right changes the screen and prints SWIPE DOWN or SWIPE UP in the serial monitor.
#include <lvgl.h>
#include <TFT_eSPI.h>
#include <ui.h>
//Add <CST816S.h> file
//define the TFT_BLK and touch pins
#include <CST816S.h>
//#define TFT_BLK D9
#define TOUCH_INT 6 //D3
#define TOUCH_SDA 11 //A04
#define TOUCH_SCL 12 //A05
#define TOUCH_RST 7 //D4
CST816S touch(TOUCH_SDA, TOUCH_SCL, TOUCH_RST, TOUCH_INT); // sda, scl, rst, irq
/*Don't forget to set Sketchbook location in File/Preferencesto the path of your UI project (the parent foder of this INO file)*/
/*Change to your screen resolution*/
static const uint16_t screenWidth = 240;
static const uint16_t screenHeight = 240;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
Serial.printf(buf);
Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
//Replaced Read the touchpad
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (!touch.available())
//Set the coordinates
data->point.x = touch.data.x;
data->point.y = touch.data.y;
Serial.print(touch.gesture());
Serial.print("\t");
Serial.print(touch.data.points);
Serial.print("\t");
Serial.print(touch.data.event);
Serial.print("\t");
Serial.print(touch.data.x);
Serial.print("\t");
Serial.println(touch.data.y);
void setup()
delay (100);
touch.begin();
LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
Serial.println( LVGL_Arduino );
Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
lv_log_register_print_cb( my_print ); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation( 3 ); /* Landscape orientation, flipped */
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
/*Initialize the display*/
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
lv_indev_drv_init( &indev_drv );
lv_indev_drv_register( &indev_drv );
ui_init();
void loop()
delay(5);
