Guys, just want to share my first hands-on projects with lvgl 9.4.0 as learning progress. Pomo app with stm32f407xx - 2.4inch LCD and XPT2046 touch.
stm32f407xx pomodoro timer
There is a issue that I’ve not understand and fixed. If you guys here have experiences on this can give me some instruction to debug. Thanks in advances.
Issue (See videos attached):
- When I tap the first button, it reacts immediately (normal).
- When I tap the second button, LVGL still triggers the first button’s event — even though the raw touch coordinates printed in the log correctly show the second button’s (different) position.
- Only after I tap the second button a second time, it correctly activates the second one.
Debug Observation:
I have tried to debug the raw position when touching, the x,y coords see to be reported correctly on each touch
Reading function
void xpt2046_read(lv_indev_t * indev, lv_indev_data_t * data)
static int16_t last_x = 0;
static int16_t last_y = 0;
static bool last_pressed = false;
bool pressed = (LV_DRV_INDEV_IRQ_READ == 0);
if (pressed) {
LV_DRV_INDEV_SPI_CS(0);
LV_DRV_INDEV_SPI_XCHG_BYTE(CMD_X_READ);
uint8_t buf = LV_DRV_INDEV_SPI_XCHG_BYTE(0);
int16_t x = buf << 8;
buf = LV_DRV_INDEV_SPI_XCHG_BYTE(CMD_Y_READ);
x += buf;
int16_t y = buf << 8;
y += buf;
LV_DRV_INDEV_SPI_CS(1);
x >>= 3;
y >>= 3;
xpt2046_corr(&x, &y);
xpt2046_avg(&x, &y);
last_x = x;
last_y = y;
data->point.x = last_x;
data->point.y = last_y;
data->state = pressed ? LV_INDEV_STATE_PRESSED : LV_INDEV_STATE_RELEASED;
/* Debug logs to verify */
if (pressed && !last_pressed)
LV_LOG_USER("[TOUCH] PRESSED (%d,%d)", last_x, last_y);
else if (!pressed && last_pressed) {
data->point.x = -1;
data->point.y = -1;
LV_LOG_USER("[TOUCH] RELEASED (%d,%d)", last_x, last_y);
last_pressed = pressed;
