Toggle button programmatically change state
toggle button, programmatically change it’s state from LV_STATE_CHECKED to LV_STATE_DEFAULT
What MCU/Processor/Board and compiler are you using? ESP32, CYD
What LVGL version are you using? 9.1
What do you want to achieve? The toggle button is labeled to “start” a count down. After toggled the toggle label changes to “stop”… If the countdown finishes successfully I want to programmatically uncheck the button and reset the label to “start”… I could reset the label manually, but I need/want to reset the toggle, which will also reset the toggle label for me.
is this the correct way to check and uncheck a toggle button? I don’t have the hardware with me at the moment and am looking for confirmation. These commands don’t seem really well documented, or at least I couldn’t find them associated much with the button.
lv_obj_add_state(tgl_btn, LV_STATE_CHECKED);
lv_obj_clear_state(tgl_btn, LV_STATE_DEFAULT);
If this is correct I am just looking for confirmation from someone with more experience than I have (just beginning with lvgl)
if you want to clear the state,you need use lv_obj_clear_state(tgl_btn, LV_STATE_CHECKED);
I don’t quite understand your needs, I guess you want to implement a countdown function?
lv_timer_t* label_count_timer;
lv_obj_t* btn;
lv_obj_t* label;
uint8_t cnt = 5;
static void label_count_evnet_cb(lv_timer_t* timer)
lv_obj_t* label = timer->user_data;
cnt--;
lv_label_set_text_fmt(label, "%d", cnt);
if (cnt == 0)
    lv_obj_clear_state(btn, LV_STATE_CHECKED);
    lv_timer_del(label_count_timer);
    label_count_timer = NULL;
static void btn_click_event_handler(lv_event_t* e)
lv_obj_t* label = (lv_obj_t*)e->user_data;
if (code == LV_EVENT_VALUE_CHANGED) {
    if (label_count_timer == NULL)
        cnt = 5;
        label_count_timer = lv_timer_create(label_count_evnet_cb, 1000, label);
int app_obj_2(lv_obj_t *parent)
btn = lv_btn_create(parent);
lv_obj_center(btn);
lv_obj_add_flag(btn, LV_OBJ_FLAG_CHECKABLE);
lv_obj_set_size(btn, 200, 60);
label = lv_label_create(btn);
lv_obj_center(label);
lv_obj_add_event_cb(btn, btn_click_event_handler, LV_EVENT_ALL, label);
return 0;
This is an example, I hope it will be helpful to you.
