Issues trying to toggle a button label. I am using Arduino IDE + VSC.
ESP32 S3
LVGL 8.3
Want the event of clicking a button to perform the following:
- Change the current label text;
So far:
char _ui_label_get_property(lv_obj_t * target);
char _ui_label_get_property(lv_obj_t *target)
char *Lbl_Txt = lv_label_get_text(target);
return Lbl_Txt;
void ui_event_Button9(lv_event_t * e)
lv_obj_t * target = lv_event_get_target(e);
if (event_code == LV_EVENT_CLICKED)
if (_ui_label_get_property(ui_Label17) == ">>")
lv_label_set_text(ui_Label16, "A");
_ui_label_set_property(ui_Label17, _UI_LABEL_PROPERTY_TEXT, "||");
lv_label_set_text(ui_Label16, "B");
_ui_label_set_property(ui_Label17, _UI_LABEL_PROPERTY_TEXT, ">>");
i think you should use strcmp() to comapre strings
EDIT: instead of comparing pointers to strings
strcmp(_ui_label_get_property(ui_Label17), ">>")
Or you can compare first characters only, but try == on strings in C language is elementary mistake. You need learn more basics.
Forgot to mention I was a C rookie…but learned a new thing.
I did the proper comparison using the strcmp() function and now, whenever I click the button, the board restarts itself.
What might be the case here? Variable type conflict?
all this is bad you mix char and char * = c basics
dont create dupli func use directly lv_label_get_text … and show code
Dont edit ui_helper files, is overwrited with next export ui.
And right code for your event
if(strcmp(lv_label_get_text(ui_Label17),">>") == 0)
overlooked something. should be
char * _ui_label_get_property(lv_obj_t *target)
Got it working.
Removed helper functions and fixed the char vs. char* mix-up.
Current code:
if(event_code == LV_EVENT_CLICKED)
char *Str_Lbl;
(strcmp(lv_label_get_text(ui_Label17), ">>") == 0) ? (Str_Lbl = "||") : (Str_Lbl = ">>");
_ui_label_set_property(ui_Label17, _UI_LABEL_PROPERTY_TEXT, Str_Lbl);
