The vertical display is abnormal.
The vertical line disappears or appears in the wrong position.
STM32F767
v8
I change another LCD, the problem exist still.
When the widget size is change, the vertical line appears in the wrong position.
(the abnormal is marked in the red rectangle)
if the chart size is set as 85% of container, there is a vertical line disappeared.
if the chart size is set as 84% of container, there is a vertical line appeared at wrong position.
In the bottom, the horizontal displays error which causes a gap on the bottom
Thank you for your suggestion. Best Wishes.
