I used LVGL7.4.
Sliding the TileView to the very bottom, and then swiping the contents of the TileView left or right, will result in a stack overflow.
So I also tested the GitHub example, and the stack overflow occurred as well.
lv_ex_tileview_1();
void lv_ex_tileview_1(void)
static lv_point_t valid_pos[] = { {0,0}, {1, 0}, {0,1},{1,1} , {0,2},{1,2} };
lv_obj_t *tileview;
tileview = lv_tileview_create(lv_scr_act(), NULL);
lv_page_set_scrl_layout(tileview, LV_LAYOUT_PRETTY_TOP);
lv_tileview_set_valid_positions(tileview, valid_pos, 6);
lv_tileview_set_edge_flash(tileview, true);
lv_obj_t * tile1 = lv_obj_create(tileview, NULL);
lv_obj_set_size(tile1, LV_HOR_RES/2, LV_VER_RES/2);
lv_tileview_add_element(tileview, tile1);
/*Tile1: just a label*/
lv_obj_t * label = lv_label_create(tile1, NULL);
lv_label_set_text(label, "Scroll down1");
lv_obj_align(label, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_size(tile1, LV_HOR_RES / 2, LV_VER_RES / 2);
//lv_obj_set_pos(tile1, LV_HOR_RES / 2, 0);
/*Tile2: just a label*/
lv_label_set_text(label, "Scroll down2");
//lv_obj_set_pos(tile1,0, LV_VER_RES / 2);
/*Tile3: just a label*/
lv_label_set_text(label, "Scroll down3");
//lv_obj_set_pos(tile1, LV_HOR_RES / 2, LV_VER_RES / 2);
/*Tile4: just a label*/
lv_label_set_text(label, "Scroll down4");
//lv_obj_set_pos(tile1,0 , LV_VER_RES);
/*Tile5: just a label*/
lv_label_set_text(label, "Scroll down5");
//lv_obj_set_pos(tile1, LV_HOR_RES/2, LV_VER_RES );
/*Tile6: just a label*/
lv_label_set_text(label, "Scroll down6");
return;
/*Tile2: a list*/
lv_obj_t * list = lv_list_create(tileview, NULL);
lv_obj_set_size(list, LV_HOR_RES/2, LV_VER_RES /2);
//lv_obj_set_pos(list, 0, LV_VER_RES);
lv_list_set_scroll_propagation(list, true);
lv_list_set_scrollbar_mode(list, LV_SCROLLBAR_MODE_OFF);
lv_tileview_add_element(tileview, list);
lv_list_add_btn(list, NULL, "One");
lv_list_add_btn(list, NULL, "Two");
lv_list_add_btn(list, NULL, "Three");
lv_list_add_btn(list, NULL, "Four");
lv_list_add_btn(list, NULL, "Five");
lv_list_add_btn(list, NULL, "Six");
lv_list_add_btn(list, NULL, "Seven");
lv_list_add_btn(list, NULL, "Eight");
/*Tile3: a button*/
lv_obj_t * tile3 = lv_obj_create(tileview, tile1);
lv_obj_set_pos(tile3, LV_HOR_RES/2, LV_VER_RES/2);
lv_tileview_add_element(tileview, tile3);
lv_obj_t * btn = lv_btn_create(tile3, NULL);
lv_obj_align(btn, NULL, LV_ALIGN_CENTER, 0, 0);
lv_tileview_add_element(tileview, btn);
label = lv_label_create(btn, NULL);
lv_label_set_text(label, "No scroll up");
