The screen resolution is 320*240。reduce the height of the container,it become scrollable, and then restore,and then Drag it back to its normal position ,It’s children‘s
relative coordinates have changed。
v8
let the textarea’s relative coordinates does not change
Code
lv_obj_t *memu;
lv_obj_t * main_cont;
static void ta_event_cb(lv_event_t * e)
lv_obj_t * ta = lv_event_get_target(e);
lv_obj_t * kb = lv_event_get_user_data(e);
if(code == LV_EVENT_FOCUSED) {
if(lv_indev_get_type(lv_indev_get_act()) != LV_INDEV_TYPE_KEYPAD) {
lv_keyboard_set_textarea(kb, ta);
lv_obj_set_style_max_height(kb, LV_HOR_RES * 2 / 3, 0);
lv_obj_update_layout(memu); /Be sure the sizes are recalculated/
lv_obj_set_height(memu, LV_VER_RES - lv_obj_get_height(kb));
lv_obj_clear_flag(kb, LV_OBJ_FLAG_HIDDEN);
lv_obj_scroll_to_view_recursive(ta, LV_ANIM_OFF);
else if(code == LV_EVENT_DEFOCUSED) {
lv_keyboard_set_textarea(kb, NULL);
lv_obj_set_height(memu, LV_VER_RES);
lv_obj_add_flag(kb, LV_OBJ_FLAG_HIDDEN);
lv_indev_reset(NULL, ta);
else if(code == LV_EVENT_READY || code == LV_EVENT_CANCEL) {
lv_obj_clear_state(ta, LV_STATE_FOCUSED);
lv_indev_reset(NULL, ta); /*To forget the last clicked object to make it focusable again*/
lv_obj_t* my_test(void)
memu = lv_obj_create(lv_scr_act());
lv_obj_remove_style_all(memu);
lv_obj_set_size(memu, lv_pct(100), LV_PCT(100));
//lv_obj_set_flex_grow(memu, 1);
lv_obj_set_flex_flow(memu, LV_FLEX_FLOW_COLUMN);
lv_obj_add_flag(memu, LV_OBJ_FLAG_EVENT_BUBBLE);
lv_obj_clear_flag(memu, LV_OBJ_FLAG_CLICKABLE);
lv_obj_t * main_header = lv_obj_create(memu);
lv_obj_set_size(main_header, LV_PCT(100), LV_SIZE_CONTENT);
lv_obj_set_flex_flow(main_header, LV_FLEX_FLOW_ROW);
lv_obj_set_flex_align(main_header, LV_FLEX_ALIGN_START, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER);
lv_obj_clear_flag(main_header, LV_OBJ_FLAG_CLICKABLE);
lv_obj_add_flag(main_header, LV_OBJ_FLAG_EVENT_BUBBLE);
main_cont = lv_obj_create(memu);
lv_obj_set_size(main_cont, LV_PCT(100), LV_SIZE_CONTENT);
lv_obj_set_flex_flow(main_cont, LV_FLEX_FLOW_COLUMN);
lv_obj_set_flex_grow(main_cont, 1);
lv_obj_set_flex_align(main_cont, LV_FLEX_ALIGN_START, LV_FLEX_ALIGN_START, LV_FLEX_ALIGN_START);
//lv_obj_clear_flag(main_cont, LV_OBJ_FLAG_CLICKABLE);
lv_obj_add_flag(main_cont, LV_OBJ_FLAG_EVENT_BUBBLE);
lv_obj_t * main_botton = lv_obj_create(memu);
lv_obj_set_size(main_botton, LV_PCT(100), LV_SIZE_CONTENT);
lv_obj_set_flex_flow(main_botton, LV_FLEX_FLOW_ROW);
lv_obj_set_flex_align(main_botton, LV_FLEX_ALIGN_START, LV_FLEX_ALIGN_CENTER, LV_FLEX_ALIGN_CENTER);
lv_obj_clear_flag(main_botton, LV_OBJ_FLAG_CLICKABLE);
lv_obj_add_flag(main_botton, LV_OBJ_FLAG_EVENT_BUBBLE);
lv_obj_t * kb = lv_keyboard_create(lv_scr_act());
lv_obj_t * password = lv_textarea_create(main_cont);
lv_textarea_set_one_line(password, true);
lv_textarea_set_password_mode(password, true);
lv_textarea_set_placeholder_text(password, "Min. 8 chars.");
lv_obj_add_event_cb(password, ta_event_cb, LV_EVENT_ALL, kb);
