The simplest and work example of LVGL + freeRTOS
I have been running the project code on my device quite successfully using TFT_eSPI and freeRTOS.
Simple code for this:
#include <Arduino.h> // include freeRTOS also
#include <TFT_eSPI.h> // Library for TFT display
TFT_eSPI tft = TFT_eSPI(); // Create object for the display
const int SCREEN_WIDTH = 360;
const int SCREEN_HEIGHT = 360;
float angle = 0.0; // Global variable for the rotation angle
// Function to draw the line
void drawLine(void *pvParameters) {
    while (true) {
        tft.fillScreen(TFT_BROWN); // Brown background
        // Center and length of the line
        int centerX = SCREEN_WIDTH / 2;
        int centerY = SCREEN_HEIGHT / 2;
        int length = 100;
        // Coordinates of the line's endpoints
        int x1 = centerX + cos(angle) * length / 2;
        int y1 = centerY + sin(angle) * length / 2;
        int x2 = centerX - cos(angle) * length / 2;
        int y2 = centerY - sin(angle) * length / 2;
        tft.drawLine(x1, y1, x2, y2, TFT_WHITE); // Draw the line
        vTaskDelay(20 / portTICK_PERIOD_MS); // Delay for frame rate
// Function to rotate the line
void rotateLine(void *pvParameters) {
    while (true) {
        angle += 0.05; // Update angle
        if (angle >= 2 * PI) angle -= 2 * PI; // Limit angle
        vTaskDelay(20 / portTICK_PERIOD_MS); // Delay for update rate
void setup() {
    tft.init();
    tft.setRotation(1); // Set display orientation
    // Create tasks for drawing and rotating
    xTaskCreate(drawLine, "Draw Line", 2048, NULL, 1, NULL);
    // xTaskCreate(rotateLine, "Rotate Line", 2048, NULL, 1, NULL);
    xTaskCreatePinnedToCore(rotateLine, "Rotate Line", 2048, NULL, 1, &rotateTask, 0); // Pin to core 0
void loop() {
    // Main loop is empty
As you can see from this simple code, you can run two tasks on two cores that is assigned to esp32s3 by default, using the flag
"extra_flags": [
"-DARDUINO_RUNNING_CORE=1",
in the board settings file
board = esp32-s3-devkitc-1-n16r8
Now I want to do a similar procedure with the library LVGL 9.3, the code for a simple example in this case is:
#include "Arduino.h"
#include <lvgl.h>
Arduino_DataBus *bus = new Arduino_ESP32QSPI(
    10 /* CS */, 9 /* SCK */, 11 /* D0 - mosi */, 12 /* D1 - miso */, 13 /* D2 - quadwp */, 14 /* D3 - quadhd */);
Arduino_GFX *gfx = new Arduino_ST77916(bus, 47 /* RST */, 0 /* rotation */, true /* IPS */, 360 /* width */, 360 /* height */);
// Global variables for angle and display settings
float angle = 0.0;
const int SCREEN_WIDTH = 480;
const int SCREEN_HEIGHT = 320;
// Backlight PIN
#define GFX_BL 15
uint32_t screenWidth;
uint32_t screenHeight;
uint32_t drawBufSize;
lv_display_t *disp;
lv_obj_t * canvas;
uint32_t millis_cb(void)
  return millis();
void my_disp_flush(lv_display_t *disp, const lv_area_t *area, uint8_t *px_map) // LVGL 9.3
  uint32_t w = lv_area_get_width(area);
  uint32_t h = lv_area_get_height(area);
  gfx->draw16bitRGBBitmap(area->x1, area->y1, (uint16_t *)px_map, w, h); // LVGL 9.3
  /*Call it to tell LVGL you are ready*/
  lv_disp_flush_ready(disp);
#define CANVAS_WIDTH  50
#define CANVAS_HEIGHT  50
// Function to create a rotating line
void drawLine(lv_obj_t *canvas) {
    /*Create a buffer for the canvas*/
    LV_DRAW_BUF_DEFINE_STATIC(draw_buf, CANVAS_WIDTH, CANVAS_HEIGHT, LV_COLOR_FORMAT_ARGB8888);
    LV_DRAW_BUF_INIT_STATIC(draw_buf);
    /*Create a canvas and initialize its palette*/
    canvas = lv_canvas_create(lv_screen_active());
    lv_canvas_set_draw_buf(canvas, &draw_buf);
    lv_canvas_fill_bg(canvas, lv_color_hex3(0xccc), LV_OPA_COVER);
    lv_obj_center(canvas);
    lv_layer_t layer;
    lv_canvas_init_layer(canvas, &layer);
    lv_draw_line_dsc_t dsc;
    lv_draw_line_dsc_init(&dsc);
    dsc.color = lv_palette_main(LV_PALETTE_RED);
    dsc.width = 4;
    dsc.round_end = 1;
    dsc.round_start = 1;
    dsc.p1.x = 15;
    dsc.p1.y = 15;
    dsc.p2.x = 35;
    dsc.p2.y = 10;
    lv_draw_line(&layer, &dsc);
    lv_canvas_finish_layer(canvas, &layer);
// Task to update the rotation angle
    // lv_obj_t *canvas = (lv_obj_t *)pvParameters; // Get the canvas object
    while (true) {
        angle += 0.05; // Increment the angle
        if (angle >= 2 * M_PI) angle -= 2 * M_PI; // Wrap around angle
        drawLine(canvas); // Call function to draw the line
void setup() {
    // Init Display
    if (!gfx->begin())
        Serial.println("gfx->begin() failed!");
    gfx->fillScreen(RGB565_YELLOW);
    #ifdef GFX_BL
        pinMode(GFX_BL, OUTPUT);
        digitalWrite(GFX_BL, HIGH);
    lv_init(); // Initialize LVGL
    /*Set a tick source so that LVGL will know how much time elapsed. */
    lv_tick_set_cb(millis_cb);
    screenWidth = gfx->width();
    screenHeight = gfx->height();
    drawBufSize = screenWidth * screenHeight;
    disp = lv_display_create(screenWidth, screenHeight);
    static void* buf1 = (lv_color_t*)heap_caps_malloc(drawBufSize, MALLOC_CAP_SPIRAM);
    static void* buf2 = (lv_color_t*)heap_caps_malloc(drawBufSize, MALLOC_CAP_SPIRAM);
    lv_display_set_buffers(disp, buf1, buf2, drawBufSize, LV_DISPLAY_RENDER_MODE_PARTIAL);
    // Create a canvas object for drawing
    // lv_obj_t *canvas = lv_canvas_create(lv_scr_act()); // No work
    lv_obj_t *canvas = lv_canvas_create( lv_screen_active()); // Work
    lv_obj_set_size(canvas, SCREEN_WIDTH, SCREEN_HEIGHT); // Set canvas size
    lv_obj_align(canvas, LV_ALIGN_CENTER, 0, 0); // Center the canvas
    // Create task for rotating line
    xTaskCreatePinnedToCore(rotateLine, "Rotate Line", 4096, NULL, 1, NULL, 0); // Pin to core 0
void loop() {
    lv_task_handler(); // Handle LVGL tasks
    vTaskDelay(5 / portTICK_PERIOD_MS); // Small delay
Platformio.ini here
build_flags =
  -D LV_CONF_SKIP
  -D LV_CONF_INCLUDE_SIMPLE
  -D LV_USE_SYSMON=1
  -D LV_USE_PERF_MONITOR=1
  -D LV_USE_PERF_MONITOR_POS="LV_ALIGN_BOTTOM_MID"
  -D LV_USE_LOG=1
  -D LV_MEM_SIZE="(128U * 1024U)"
  -D LV_USE_FREERTOS_TASK_NOTIFY=1
  -D LV_DEF_REFR_PERIOD=5
The code compiles and loads into the device fine, but the result is only a yellow screen:
If I uncomment the line from the Setup section:
lv_obj_t *canvas = lv_canvas_create(lv_screen_active()); // Create canvas
The device will load the image, but there are no rotations and the device will reboot.
ELF file SHA256: 23b901996f8eec9f
Rebooting…
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0xb (SPI_FAST_FLASH_BOOT)
Saved PC:0x40377834
#0 0x40377834 in esp_restart_noos at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/port/soc/esp32s3/system_internal.c:151 (discriminator 1)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x4bc
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a0c
entry 0x403c98d0
E (11933) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (11933) task_wdt: - IDLE0 (CPU 0)
E (11933) task_wdt: Tasks currently running:
E (11933) task_wdt: CPU 0: Rotate Line
E (11933) task_wdt: CPU 1: loopTask
E (11933) task_wdt: Aborting.
abort() was called at PC 0x4204463c on core 0
#0 0x4204463c in task_wdt_isr at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/task_wdt.c:176 (discriminator 3)
Backtrace: 0x40377bfe:0x3fc94c50 0x4037b339:0x3fc94c70 0x40381a45:0x3fc94c90 0x4204463c:0x3fc94d10 0x40378e41:0x3fc94d30 0x4205d8b8:0x3fced190 0x4201274f:0x3fced1b0 0x4201293e:0x3fced1e0 0x42011aa8:0x3fced200 0x42012b2e:0x3fced220 0x42023e50:0x3fced240 0x42018419:0x3fced270 0x420019a1:0x3fced290 0x42001a81:0x3fced360
#0 0x40377bfe in panic_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/panic.c:408
#1 0x3fc94c50 in port_IntStack at ??:?
#2 0x4037b339 in esp_system_abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/esp_system.c:137
#3 0x3fc94c70 in port_IntStack at ??:?
#4 0x40381a45 in abort at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/newlib/abort.c:46
#5 0x3fc94c90 in port_IntStack at ??:?
#6 0x4204463c in task_wdt_isr at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/task_wdt.c:176 (discriminator 3)
#7 0x3fc94d10 in port_IntStack at ??:?
#8 0x40378e41 in _xt_lowint1 at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port/xtensa/xtensa_vectors.S:1118
#9 0x3fc94d30 in port_IntStack at ??:?
#10 0x4205d8b8 in lv_assert_handler at lib/lvgl/src/misc/lv_assert.c:37
#11 0x4201274f in block_locate_free at lib/lvgl/src/stdlib/builtin/lv_tlsf.c:774
(inlined by) block_locate_free at lib/lvgl/src/stdlib/builtin/lv_tlsf.c:754
#12 0x4201293e in lv_tlsf_malloc at lib/lvgl/src/stdlib/builtin/lv_tlsf.c:1101
#13 0x42011aa8 in lv_malloc_core at lib/lvgl/src/stdlib/builtin/lv_mem_core_builtin.c:144
#14 0x42012b2e in lv_malloc_zeroed at lib/lvgl/src/stdlib/lv_mem.c:100
(inlined by) lv_malloc_zeroed at lib/lvgl/src/stdlib/lv_mem.c:92
#15 0x42023e50 in lv_obj_class_create_obj at lib/lvgl/src/core/lv_obj_class.c:51
#16 0x42018419 in lv_canvas_create at lib/lvgl/src/widgets/canvas/lv_canvas.c:62
#17 0x420019a1 in drawLine(_lv_obj_t*) at src/RTOS_LVGL_9_simple.cpp:59
#18 0x42001a81 in rotateLine(void*) at src/RTOS_LVGL_9_simple.cpp:90
Unfortunately, I didn’t see any examples of lvgl + freeRTOS in the repository
or any working examples on the Internet :roll_eyes:
Hi @brightproject,
Thank you to open this topic. Please, try to use this template for PlatformIO
