Program Framework:
The system is developed using FREERTOS 10.2+LVGL 7.11. Three tasks are created using FreeRTOS: Task A, responsible for creating LVGL pages with the highest priority, executing every 200ms; Task B, which only executes lv_task_handle, has the second-highest priority, and executes every 10ms; Task C performs other operations, with the lowest priority, executing every 100ms.
Normal Behavior:
Clicking on imgbtn causes its background to change to yellow and then revert to gray, followed by a transition to the next page.
Abnormal Behavior:
Upon clicking the btn_start button, there is a probability of the screen freezing and failing to transition to the next page.
Implementation of Buttons on the Page:
On the current page, there are two controls: imgbtn and cont. Imgbtn has three states: pressed, released, and lost. In its default state, imgbtn is gray. When pressed, imgbtn generates an LV_EVENT_PRESSED event, changing its color to yellow. Upon release, imgbtn generates an LV_EVENT_RELEASED event, restoring its color to gray and transitioning to the next page. When LV_EVENT_PRESS_LOST occurs, imgbtn reverts to gray. Additionally, there is a custom event that, every second, toggles the visibility of the cont control. The cont control has a transparent background with opacity set to 0, border opacity set to 255, and a white border color. It is initially set to be hidden.
GD32F470ZKT6 + KEIL5.36
LVGL7.11
The screen no stuck.
Upon enabling LVGL’s LOG and DEBUG, an invalid pointer error is indicated. The issue is traced to lv_obj_set_state, specifically lv_anim_set_start_cb(&a, trans_anim_start_cb), where the address of pointer ‘a’ changes. Therefore, I would like to inquire about why this pointer is changing and if there are methods to prevent such errors.
