Description:as the title, the screen is shake when button is pressed for the case of STM32H743 with SD CARD. But In the case of stm32F767 with SD card, the screen is normal.
STM32H743(abnormal) and STM32F767(normal)
8.0
fix the abnormal of screen in the case of STM32H743 with SD card.
I compare the case of H743 with SD card, H743 without SD card, F767 with SD card, only the first case is abnormal, the other two are normal
Since it is independent of code but related to the mcu. I do not post the code here. The different between the abnormal case and normal case is the MDMA is enable in the case of abnormal(the MDAM must be enable in the case of H743 with SD in CubeMX)
the abnormal case(H743 with SD card):
the normal case (F767 with SD card)
Thanks for your advice, best wishes
