Hi,The loop call to lv_img_set_angle () causes an image to be incomplete.
Can you reproduce this in the simulator? Can you provide a code sample (please make sure to include your image’s .c
file as well)?
Thank you for your answer,
code sample:
static lv_img_dsc_t mbuf;
static lv_img_dsc_t hbuf;
static lv_img_dsc_t sbuf;
static lv_img_dsc_t bgbuf;
static int16_t h_arc, m_arc, s_arc;
static uint8_t m_ref, h_ref;
lv_obj_t *hobj, *mobj, *sobj;
static void clockTask(lv_task_t *t)
s_arc+=60;
if (s_arc >= 3600)
m_arc += 60;
if (m_arc % 720 == 0)
h_arc += 60;
h_arc %= 3600;
lv_img_set_angle(hobj, h_arc);
s_arc = 0;
m_arc %= 3600;
lv_img_set_angle(mobj, m_arc);
lv_img_set_angle(t->user_data, s_arc);
void clock_dis(void)
bgbuf.data = BP_IMG;
bgbuf.data_size = 185*185*3;
bgbuf.header.always_zero = 0;
bgbuf.header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA;
bgbuf.header.w = 185;
bgbuf.header.h = 185;
lv_obj_t *bgobj;
bgobj = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(bgobj, &bgbuf);
lv_obj_align(bgobj, NULL, LV_ALIGN_CENTER, 0, 0);
hbuf.data = H_IMG;
hbuf.data_size = 8*46*3;
hbuf.header.always_zero = 0;
hbuf.header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA;
hbuf.header.w = 8;
hbuf.header.h = 46;
hobj = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(hobj, &hbuf);
lv_obj_align(hobj, bgobj, LV_ALIGN_CENTER, 0, -23);
lv_img_set_pivot(hobj, 4, 46);
mbuf.data = M_IMG;
mbuf.data_size = 6*66*3;
mbuf.header.always_zero = 0;
mbuf.header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA;
mbuf.header.w = 6;
mbuf.header.h = 66;
mobj = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(mobj, &mbuf);
lv_obj_align(mobj, NULL, LV_ALIGN_CENTER, 0, -33);
lv_img_set_pivot(mobj, 3, 66);
sbuf.data = S_IMG;
sbuf.data_size = 7*70*3;
sbuf.header.always_zero = 0;
sbuf.header.cf = LV_IMG_CF_TRUE_COLOR_ALPHA;
sbuf.header.w = 7;
sbuf.header.h = 70;
sobj = lv_img_create(lv_scr_act(), NULL);
lv_img_set_src(sobj, &sbuf);
lv_obj_align(sobj, NULL, LV_ALIGN_CENTER, 0, -33);
lv_img_set_pivot(sobj, 4, 66);
lv_task_create(clockTask, 1000, LV_TASK_PRIO_LOW, sobj);
const unsigned char S_IMG[] =
0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x1f, 0x84, 0xf3, 0xd8, 0x84, 0xf3, 0x88, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00,
0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x3f, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xc4, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00,
0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x3c, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xbf, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00,
0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x34, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xbb, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00,
0x84, 0xf3, 0x00, 0x84, 0xf3, 0x00, 0x84, 0xf3, 0x60, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xcf, 0x84, 0xf3, 0x17, 0x84, 0xf3, 0x00,
0x84, 0xf3, 0x07, 0x84, 0xf3, 0x9b, 0x84, 0xf3, 0xfc, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xe3, 0x84, 0xf3, 0x47,
0x84, 0xf3, 0x7c, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xe7,
0x84, 0xf3, 0xdb, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xf0,
0x84, 0xf3, 0xe7, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xec,
0x84, 0xf3, 0xbf, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xff, 0x84, 0xf3, 0xf4,
0x84, 0xf3, 0x3f, 0x84, 0xf3, 0xe4, 0x84, 0xf3, 0xec, 0x84, 0xf3, 0xec, 0x84, 0xf3, 0xec, 0x84, 0xf3, 0xec, 0x84, 0xf3, 0xac,
const unsigned char M_IMG[] =
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x2b, 0x6a, 0x52, 0x88, 0x6a, 0x52, 0x8b, 0x6a, 0x52, 0x2f, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x24, 0x6a, 0x52, 0xe8, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xec, 0x6a, 0x52, 0x2f,
0x6a, 0x52, 0xa0, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xa7,
0x6a, 0x52, 0xc0, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xc0,
0x6a, 0x52, 0xbf, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xbf,
0x6a, 0x52, 0xab, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xaf,
0x6a, 0x52, 0x30, 0x6a, 0x52, 0xf4, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xf8, 0x6a, 0x52, 0x3c,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x37, 0x6a, 0x52, 0xf8, 0x6a, 0x52, 0xf8, 0x6a, 0x52, 0x3c, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x03, 0x6a, 0x52, 0xf0, 0x6a, 0x52, 0xf0, 0x6a, 0x52, 0x03, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x0b, 0x6a, 0x52, 0xf3, 0x6a, 0x52, 0xf3, 0x6a, 0x52, 0x0b, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x0c, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0x0c, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x07, 0x6a, 0x52, 0x8c, 0x6a, 0x52, 0x8c, 0x6a, 0x52, 0x07, 0x6a, 0x52, 0x00,
const unsigned char H_IMG[] =
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x08, 0x6a, 0x52, 0x7b, 0x6a, 0x52, 0xcf, 0x6a, 0x52, 0xd3, 0x6a, 0x52, 0x83, 0x6a, 0x52, 0x0f, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x04, 0x6a, 0x52, 0xb8, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xc7, 0x6a, 0x52, 0x0b,
0x6a, 0x52, 0x64, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0x77,
0x6a, 0x52, 0xb3, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xb7,
0x6a, 0x52, 0xbb, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xb8,
0x6a, 0x52, 0xb8, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xb8,
0x6a, 0x52, 0xbb, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xbb,
0x6a, 0x52, 0xab, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xb0,
0x6a, 0x52, 0x4b, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0x5c,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x90, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0xff, 0x6a, 0x52, 0x9f, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x48, 0x6a, 0x52, 0xf4, 0x6a, 0x52, 0xfb, 0x6a, 0x52, 0x57, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0xeb, 0x6a, 0x52, 0xf7, 0x6a, 0x52, 0x08, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x07, 0x6a, 0x52, 0xec, 0x6a, 0x52, 0xf7, 0x6a, 0x52, 0x13, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x07, 0x6a, 0x52, 0xf3, 0x6a, 0x52, 0xfc, 0x6a, 0x52, 0x13, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00,
0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x04, 0x6a, 0x52, 0xd0, 0x6a, 0x52, 0xdb, 0x6a, 0x52, 0x10, 0x6a, 0x52, 0x00, 0x6a, 0x52, 0x00,
Next time please format your code like this and upload long codes as files for better readibility.
your
code
here
The lv_img_dsc_t
parts of the images are missing so I can’t reproduce the issue.
There were some image rotation related fixes in the master
branch. Maybe these were fixed your issue.
Can you give it try?
thank you kisvegabor , I am sorry, This is the first time information has been posted on the forum.I’m not good at using it.I will test the result you gave me and reply to you after the test. Thank you!
Hi,kisvegabor,The latest master branch is ok, thank you.
