Hi everyone, They are developing one project, I include image files as arrays, everything works perfectly. I decided to switch to storing files on a USB flash drive. Enabled Ntfs support, files are successfully written and read. In the image loading code, I changed the line: it was - /lv_img_set_src(img1, &bg_block); it became - lv_img_set_src(img1, "F:/bg_clock_passat.bin ");
I run the program: the picture is loaded partially (see photo # 1), when debugging is enabled, this is written:
[Warn] (1.357, +272) _lv_img_cache_open: Image draw cannot open the image resource (in lv_img_cache.c line #125)
[Warn] (1.357, +0) lv_draw_img: Image draw error (in lv_draw_img.c line #81)
[Warn] (1.389, +32) _lv_img_cache_open: Image draw cannot open the image resource (in lv_img_cache.c line #125)
[Warn] (1.390, +1) lv_draw_img: Image draw error (in lv_draw_img.c line #81)
[Warn] (1.394, +4) _lv_img_cache_open: Image draw cannot open the image resource (in lv_img_cache.c line #125)
[Warn] (1.395, +1) lv_draw_img: Image draw error (in lv_draw_img.c line #81)
[Warn] (1.399, +4) _lv_img_cache_open: Image draw cannot open the image resource (in lv_img_cache.c line #125)
[Warn] (1.400, +1) lv_draw_img: Image draw error (in lv_draw_img.c line #81)
I raise the debugging level to Trace and the picture starts loading completely (see photo #2)
The image file is successfully read through the FATF:
lv_fs_fatfs_init OK;
Initializing W25Q: OK
f_mount(&FileSystemObject,3 ,1) → 0
f_chdrive(3:) → 0
f_get free(0:, &fre_clust, &FileSystemObject) → 0
The total amount of disk space is 2013 KB. A library of 1989 is available.
Root directory:
FILE log.txt size 53
FILE log1.txt size 526
FILE log2.txt size 1100
The size of the bg_clock_passat file.bin 58628
THE test_o_cr_file FILE.hopper size 115204
(total: 0 folders, 5 files)
What could be my mistake?
STM32F413
v.8.3.3
What have you tried so far
changed the display update time in lv_conf.h, tried to pass the debugger on the code
#define LV_USE_FS_FATFS 1
#if LV_USE_FS_FATFS
#define LV_FS_FATFS_LETTER 'F' /*Set an upper cased letter on which the drive will accessible (e.g. 'A')*/
lv_obj_t * img1 = lv_img_create(screen_metrics_clock);
lv_img_set_src(img1, "F:/bg_clock_passat.bin");
lv_obj_align(img1, LV_ALIGN_CENTER, 0, 0);
lv_obj_set_style_img_recolor_opa(img1, 50, 0);
lv_obj_set_size(img1, GetWidthLCD(), GetHeightLCD());
Photo1 -
Photo2 -
