- When the device switches the interface, will refresh out a part of the picture
Please fill the template to provide enough information to investigate your issue.
> ## Important: posts that do not use this template will be ignored or closed.
>## Before posting
> - Get familiar with [Markdown](https://forum.lvgl.io/t/get-familiar-with-markdown/403) to format and structure your post
> - Be sure to update [lvgl](https://github.com/littlevgl/lvgl) from the latest version from the `master` branch.
> - Try to reproduce the issue in a [Simulator](https://docs.littlevgl.com/en/html/get-started/pc-simulator.html). If it's working there then probably it's not a LittlevGL issue.
> *Delete this section if you read and applied the mentioned points.*
## Description
### What MCU/Processor/Board and compiler are you using?
### What do you experience?
Give a detailed description. "It doesn't work" is not enough information for us to diagnose the issue.
### What do you expect?
## Code to reproduce
Add a code snippet to reproduce the issue in the simulator. It should contain only the relevant code which can be compiled. **Bug reports without code snippets or with erroneous code snippets will not be reviewed.**
You should format the code blocks like this:
```c
## Screenshot and/or video
If possible, add screenshots and/or videos about the current issue.
