The glitch in the display when the cursor moving
I create a chart with 1000 points in my display, I add a cursor to the chart, and when the cursor moves through the chart continuously by the timer, after a while glitch occurs in my display.
when I place the LCD buffer(1280*400) in the SDRAM this problem happens but when I use stm32 RAM instead of the SDRAM, there is no problem.
I think this problem is not related to the SDRAM config because it happens only when the chart is displayed.
STM32H7A3
V8.7
void create_main_screen(void){
    clear_screen();
    create_main_frame();
    init_objects_styles();
    create_test_chart();
    lv_timer_t *lvgl_timer_test_chart = lv_timer_create(lvgl_timer_test_chart_callback, 300, NULL);
static void create_test_chart()
	test_chart = lv_chart_create(obj_mid_bar);
	lv_obj_set_size(test_chart, 1100, 250);
	lv_obj_align(test_chart, LV_ALIGN_CENTER, 0, 10);
	lv_obj_add_style(test_chart, &style_trend_chart_bg, LV_PART_MAIN);
	lv_obj_add_style(test_chart, &style_trend_chart_ticks, LV_PART_TICKS);
	lv_obj_add_style(test_chart, &style_trend_chart_cursor, LV_PART_CURSOR);
	lv_chart_set_type(test_chart, LV_CHART_TYPE_LINE);
	lv_chart_set_update_mode(test_chart, LV_CHART_UPDATE_MODE_CIRCULAR);
	lv_chart_set_div_line_count(test_chart, 0, 0);
	lv_chart_set_point_count(test_chart, 1000);
	test_chart_series = lv_chart_add_series(test_chart,
			lv_color_make(0, 180, 230), LV_CHART_AXIS_PRIMARY_Y);
	lv_chart_set_range(test_chart, LV_CHART_AXIS_PRIMARY_Y,
	SPO2_MIN_LOWERBOUND, 300);
	lv_chart_set_all_value(test_chart, test_chart_series,
			SPO2_MIN_LOWERBOUND);
	lv_chart_set_axis_tick(test_chart, LV_CHART_AXIS_PRIMARY_Y, 15, 10, 6,
			5,
			true, 45);
	test_chart_cursor = lv_chart_add_cursor(test_chart, lv_color_white(),
			LV_DIR_VER);
	trend_hidden_serires[1] = lv_chart_add_series(test_chart,
			lv_color_black(), LV_CHART_AXIS_PRIMARY_Y
	lv_chart_set_cursor_point(test_chart, test_chart_cursor,
			trend_hidden_serires[1], 0);
	for(uint16_t i=0;i<1000;i++){
		test_chart_series->y_points [i] = i % 150;
	lv_chart_refresh(test_chart);
static void lvgl_timer_test_chart_callback(struct _lv_timer_t *timer){
	static uint16_t cnt23 = 0;
	static uint16_t id_plus = 0;
	if(cnt23++<1000){
		id_plus++;
	}else if(cnt23++>1000){
		id_plus--;
		cnt23 = 0;
	lv_chart_set_cursor_point(test_chart, test_chart_cursor, test_chart_series, id_plus);
glitch.zip (2.6 MB)
