To set label width seems not working when call set width first then call set long mode function to a label. What’s the difference between this?
lv_obj_set_width(label, 180);
lv_label_set_long_mode(label, LV_LABEL_LONG_BREAK);
The code above set width function seems not working ,the width of the label only contain two chinese chars,the long mode works and the line wraps.
The code above works good,the width is as set.
Is there a way to know which function should be called before others>
stm32l476 keil mdk ac5
