The chart does not draw
I want the values from the sensor to be transmitted and displayed in the chart
ESP32-Wrower-B
correct display of values on the chart
lv_obj_t * chart_test(lv_obj_t * cont){
	chart_one = lv_chart_create(cont, NULL);
	lv_obj_set_size(chart_one, 270, 400);
	lv_obj_align(chart_one, NULL, LV_ALIGN_IN_TOP_MID, 0, 0);
	lv_chart_set_type(chart_one, LV_CHART_TYPE_LINE);
	lv_chart_set_series_opa(chart_one, LV_OPA_70);
	lv_chart_set_series_width(chart_one, 4);
	lv_chart_set_range(chart_one, 0, 100);
	lv_chart_set_style(chart_one, LV_CHART_STYLE_MAIN, &lv_style_transp);
    ser_one = lv_chart_add_series(chart_one, LV_COLOR_DEEPSKYBLUE);
    lv_chart_set_next(chart_one, ser_one,0);
	lv_chart_refresh(chart_one);
	return chart_one;
from the sensor
lv_task_create( chart_refresher_task, 1024, LV_TASK_PRIO_MID, NULL);
void chart_refresher_task(void *p)
    int arr[2];
    sprintf(arr, "%d", (int)sensor_data.temp);
    lv_chart_set_next(chart_1, ser_one,arr);
## Screenshot and/or video
I assume chart_test gets called. Can you put a debug statement in chart_refresher_task and see if it gets called?
he called, watch the video what is happening on the screenVID_20200416_141940.zip (3.2 MB)
I think the data is just out of scope
It looks weird:
    int arr[2];
sptrinf creates a string which you put into an int array, an pass it to lv_chart_set_next which needs a single int.
It should work:
    lv_chart_set_next(chart_1, ser_one, sensor_data.temp);
it worked with labele so i thought it would work for chart too, but ok, i`am testing
its worked)))
thancks so much)
A good place to check that is the documentation.
lv_chart_set_next takes an integer as the new value. lv_label_set_text takes a char * (string) as the new value.
You are welcome!
Probably there was a warning for it too. I suggest checking them carefully because they help to identify issues like this.
