The `bidi` and Persian/Arabic character settings are reversing the Arabic numerics
Hi all,
I have encountered a problem with the Bidi algorithm when using the following options:
#define LV_USE_BIDI 1
#define LV_USE_ARABIC_PERSIAN_CHARS 1
With both options enabled, Persian text is displayed correctly, but Persian/Arabic-Indic digits inside the string are reversed.
For example:
شنبه، ۱۵ مهر
is displayed as:
شنبه، ۵۱ مهر
If I disable the Bidi algorithm, the digit order is correct, but the Persian text is displayed in the wrong order.
I also encountered another issue when “LV_USE_ARABIC_PERSIAN_CHARS” is enabled. LVGL seems to convert the Persian digit “۲” (U+06F2) to “۰” (U+06F0).
For example, this string:
۱۲:۴۵
is displayed as:
۱۰:۴۵
I traced this to “ap_chars_map” and temporarily removed the Persian digits (۰–۹) from the map:
{206, 0x06F0, -1, 2, 0, {0, 0}}, // ۰
{207, 0x06F1, 0, 0, 0, {0, 0}}, // ۱
{208, 0x06F2, 0, 0, 0, {0, 0}}, // ۲
{209, 0x06F3, 0, 0, 0, {0, 0}}, // ۳
{210, 0x06F4, 0, 0, 0, {0, 0}}, // ۴
{211, 0x06F5, 0, 0, 0, {0, 0}}, // ۵
{212, 0x06F6, 0, 0, 0, {0, 0}}, // ۶
{213, 0x06F7, 0, 0, 0, {0, 0}}, // ۷
{214, 0x06F8, 0, 0, 0, {0, 0}}, // ۸
{215, 0x06F9, 0, 0, 0, {0, 0}}, // ۹
After removing these entries, the digit-conversion issue is fixed, but the Bidi issue remains: Persian digits are still displayed in reverse order.
So, in summary:
1. “LV_USE_BIDI = 1” + “LV_USE_ARABIC_PERSIAN_CHARS = 1”
  • Persian text: correct
  • Persian digits: reversed (“۱۵” → “۵۱”)
2. “LV_USE_BIDI = 0”
  • Persian digits: correct
  • Persian text: reversed
3. “LV_USE_ARABIC_PERSIAN_CHARS = 1”
  • Persian digit “۲” is incorrectly converted to “۰” in some cases.
Has anyone encountered this issue or know where the digit reordering happens in LVGL’s Bidi implementation?
Regards,
Ehsan
