STM32 NUCLEO-F756ZG, STM32CubeIDE, 2.8 inch Resistive touch LCD ( Pico-ResTouch-LCD-2.8 - Waveshare Wiki)
Latest
Touch area fitting the buttons position.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "cmsis_os.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "lvgl.h"
#include "./src/drivers/display/st7789/lv_st7789.h"
#include <stdbool.h>
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
#define LCD_H_RES 240
#define LCD_V_RES 320
#define BUS_SPI1_POLL_TIMEOUT 0x1000U
#define XPT2046_CS_LOW() HAL_GPIO_WritePin(TP_CS_GPIO_Port, TP_CS_Pin, GPIO_PIN_RESET)
#define XPT2046_CS_HIGH() HAL_GPIO_WritePin(TP_CS_GPIO_Port, TP_CS_Pin, GPIO_PIN_SET)
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
SPI_HandleTypeDef hspi1;
SPI_HandleTypeDef hspi2;
DMA_HandleTypeDef hdma_spi1_tx;
DMA_HandleTypeDef hdma_spi2_tx;
UART_HandleTypeDef huart6;
osThreadId defaultTaskHandle;
/* USER CODE BEGIN PV */
osThreadId LvglTaskHandle;
lv_display_t *lcd_disp;
volatile int lcd_bus_busy = 0;
lv_indev_t * indev;
uint8_t tx_buffer1[50] = "Detected!\n\r";
uint8_t tx_buffer2[50] = "None\n\r";
/* USER CODE END PV */
void SystemClock_Config(void);
static void MX_DMA_Init(void);
static void MX_SPI1_Init(void);
static void MX_SPI2_Init(void);
static void MX_USART6_UART_Init(void);
void StartDefaultTask(void const * argument);
/* USER CODE BEGIN PFP */
void ui_init(lv_display_t *disp);
void LVGL_Task(void const *argument);
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
static uint16_t xpt2046_read(uint8_t command) {
uint8_t tx[3] = {command, 0x00, 0x00};
uint8_t rx[3];
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
HAL_SPI_Init(&hspi1);
XPT2046_CS_LOW();
HAL_SPI_TransmitReceive(&hspi1, tx, rx, 3, HAL_MAX_DELAY);
XPT2046_CS_HIGH();
return((rx[1] << 8) | rx[2]) >> 3;
static bool touchpad_is_pressed(int32_t * x, int32_t * y) {
const uint8_t CMD_X = 0x90;
const uint8_t CMD_Y = 0xD0;
uint16_t raw_y = xpt2046_read(CMD_Y);
uint16_t raw_x = xpt2046_read(CMD_X);
snprintf(tx_buffer1, sizeof(tx_buffer1), "X:%u Y:%u\r\n", *x, *y);
HAL_UART_Transmit(&huart6, (uint8_t*)tx_buffer1, strlen(tx_buffer1), HAL_MAX_DELAY);
if (raw_x > 100 && raw_x < 4000 && raw_y < 4000)
*x = (raw_x - 511) * LCD_V_RES / (3968 - 511);
*y = LCD_H_RES - ((raw_y - 511) * LCD_H_RES / (3712 - 511));
return true;
return false;
/* USER CODE END 0 */
* @brief The application entry point.
* @retval int
int main(void)
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
HAL_Init();
/* USER CODE BEGIN Init */
/* USER CODE END Init */
SystemClock_Config();
/* USER CODE BEGIN SysInit */
/* USER CODE END SysInit */
MX_GPIO_Init();
MX_DMA_Init();
MX_SPI1_Init();
MX_SPI2_Init();
MX_USART6_UART_Init();
/* USER CODE BEGIN 2 */
/* USER CODE END 2 */
/* USER CODE BEGIN RTOS_MUTEX */
/* add mutexes, ... */
/* USER CODE END RTOS_MUTEX */
/* USER CODE BEGIN RTOS_SEMAPHORES */
/* add semaphores, ... */
/* USER CODE END RTOS_SEMAPHORES */
/* USER CODE BEGIN RTOS_TIMERS */
/* start timers, add new ones, ... */
/* USER CODE END RTOS_TIMERS */
/* USER CODE BEGIN RTOS_QUEUES */
/* add queues, ... */
/* USER CODE END RTOS_QUEUES */
/* Create the thread(s) */
/* definition and creation of defaultTask */
osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128);
defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
/* USER CODE BEGIN RTOS_THREADS */
/* add threads, ... */
osThreadDef(LvglTask, LVGL_Task, osPriorityIdle, 0, 1024);
LvglTaskHandle = osThreadCreate(osThread(LvglTask), NULL);
/* USER CODE END RTOS_THREADS */
/* Start scheduler */
osKernelStart();
/* We should never get here as control is now taken by the scheduler */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @retval None
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Configure LSE Drive Capability
HAL_PWR_EnableBkUpAccess();
/** Configure the main internal regulator output voltage
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_BYPASS;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 4;
RCC_OscInitStruct.PLL.PLLN = 216;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 3;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Activate the Over-Drive mode
if (HAL_PWREx_EnableOverDrive() != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_7) != HAL_OK)
Error_Handler();
* @brief SPI1 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN SPI1_Init 0 */
/* USER CODE END SPI1_Init 0 */
/* USER CODE BEGIN SPI1_Init 1 */
/* USER CODE END SPI1_Init 1 */
/* SPI1 parameter configuration*/
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 7;
hspi1.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
hspi1.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN SPI1_Init 2 */
/* USER CODE END SPI1_Init 2 */
* @brief SPI2 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN SPI2_Init 0 */
/* USER CODE END SPI2_Init 0 */
/* USER CODE BEGIN SPI2_Init 1 */
/* USER CODE END SPI2_Init 1 */
/* SPI2 parameter configuration*/
hspi2.Instance = SPI2;
hspi2.Init.Mode = SPI_MODE_MASTER;
hspi2.Init.Direction = SPI_DIRECTION_2LINES;
hspi2.Init.DataSize = SPI_DATASIZE_8BIT;
hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi2.Init.CLKPhase = SPI_PHASE_1EDGE;
hspi2.Init.NSS = SPI_NSS_SOFT;
hspi2.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi2.Init.CRCPolynomial = 7;
hspi2.Init.CRCLength = SPI_CRC_LENGTH_DATASIZE;
hspi2.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
if (HAL_SPI_Init(&hspi2) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN SPI2_Init 2 */
/* USER CODE END SPI2_Init 2 */
* @brief USART6 Initialization Function
* @param None
* @retval None
/* USER CODE BEGIN USART6_Init 0 */
/* USER CODE END USART6_Init 0 */
/* USER CODE BEGIN USART6_Init 1 */
/* USER CODE END USART6_Init 1 */
huart6.Instance = USART6;
huart6.Init.BaudRate = 115200;
huart6.Init.WordLength = UART_WORDLENGTH_8B;
huart6.Init.StopBits = UART_STOPBITS_1;
huart6.Init.Parity = UART_PARITY_NONE;
huart6.Init.Mode = UART_MODE_TX_RX;
huart6.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart6.Init.OverSampling = UART_OVERSAMPLING_16;
huart6.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart6.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_UART_Init(&huart6) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART6_Init 2 */
/* USER CODE END USART6_Init 2 */
* Enable DMA controller clock
/* DMA controller clock enable */
__HAL_RCC_DMA2_CLK_ENABLE();
__HAL_RCC_DMA1_CLK_ENABLE();
/* DMA interrupt init */
/* DMA1_Stream4_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA1_Stream4_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(DMA1_Stream4_IRQn);
/* DMA2_Stream3_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA2_Stream3_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(DMA2_Stream3_IRQn);
* @param None
* @retval None
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOH_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOG_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(LCD_CS_GPIO_Port, LCD_CS_Pin, GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOB, LD1_Pin|GPIO_PIN_1|LD3_Pin|LD2_Pin, GPIO_PIN_RESET);
HAL_GPIO_WritePin(GPIOB, LCD_DCX_Pin|LCD_RESET_Pin|TP_CS_Pin, GPIO_PIN_SET);
HAL_GPIO_WritePin(USB_PowerSwitchOn_GPIO_Port, USB_PowerSwitchOn_Pin, GPIO_PIN_RESET);
/*Configure GPIO pin : USER_Btn_Pin */
GPIO_InitStruct.Pin = USER_Btn_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(USER_Btn_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : RMII_MDC_Pin */
GPIO_InitStruct.Pin = RMII_MDC_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
GPIO_InitStruct.Alternate = GPIO_AF11_ETH;
HAL_GPIO_Init(RMII_MDC_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : RMII_REF_CLK_Pin RMII_MDIO_Pin */
GPIO_InitStruct.Pin = RMII_REF_CLK_Pin|RMII_MDIO_Pin;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
/*Configure GPIO pin : LCD_CS_Pin */
GPIO_InitStruct.Pin = LCD_CS_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
HAL_GPIO_Init(LCD_CS_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : LD1_Pin PB1 LD3_Pin LD2_Pin */
GPIO_InitStruct.Pin = LD1_Pin|GPIO_PIN_1|LD3_Pin|LD2_Pin;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/*Configure GPIO pin : LCD_DCX_Pin */
GPIO_InitStruct.Pin = LCD_DCX_Pin;
HAL_GPIO_Init(LCD_DCX_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : LCD_RESET_Pin TP_CS_Pin */
GPIO_InitStruct.Pin = LCD_RESET_Pin|TP_CS_Pin;
/*Configure GPIO pin : RMII_TXD1_Pin */
GPIO_InitStruct.Pin = RMII_TXD1_Pin;
HAL_GPIO_Init(RMII_TXD1_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : STLK_RX_Pin STLK_TX_Pin */
GPIO_InitStruct.Pin = STLK_RX_Pin|STLK_TX_Pin;
GPIO_InitStruct.Alternate = GPIO_AF7_USART3;
HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
/*Configure GPIO pin : USB_PowerSwitchOn_Pin */
GPIO_InitStruct.Pin = USB_PowerSwitchOn_Pin;
HAL_GPIO_Init(USB_PowerSwitchOn_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : USB_OverCurrent_Pin */
GPIO_InitStruct.Pin = USB_OverCurrent_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
HAL_GPIO_Init(USB_OverCurrent_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : TP_IRQ_Pin */
GPIO_InitStruct.Pin = TP_IRQ_Pin;
HAL_GPIO_Init(TP_IRQ_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : USB_SOF_Pin USB_ID_Pin USB_DM_Pin USB_DP_Pin */
GPIO_InitStruct.Pin = USB_SOF_Pin|USB_ID_Pin|USB_DM_Pin|USB_DP_Pin;
GPIO_InitStruct.Alternate = GPIO_AF10_OTG_FS;
/*Configure GPIO pin : USB_VBUS_Pin */
GPIO_InitStruct.Pin = USB_VBUS_Pin;
HAL_GPIO_Init(USB_VBUS_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : RMII_TX_EN_Pin RMII_TXD0_Pin */
GPIO_InitStruct.Pin = RMII_TX_EN_Pin|RMII_TXD0_Pin;
HAL_GPIO_Init(GPIOG, &GPIO_InitStruct);
/*Configure GPIO pins : PB8 PB9 */
GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9;
GPIO_InitStruct.Mode = GPIO_MODE_AF_OD;
GPIO_InitStruct.Alternate = GPIO_AF4_I2C1;
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
static void touchpad_read(lv_indev_t * indev_drv, lv_indev_data_t * data)
static int32_t last_x = 30;
static int32_t last_y = 30;
//if(touchpad_is_pressed(&last_x, &last_y))
//HAL_GPIO_WritePin(LCD_CS_GPIO_Port, LCD_CS_Pin, GPIO_PIN_SET); //off lcd cs pin
// snprintf(tx_buffer1, sizeof(tx_buffer1), "X:%u Y:%u\r\n", last_x, last_y);
// HAL_UART_Transmit(&huart6, (int32_t*)tx_buffer1, strlen(tx_buffer1), HAL_MAX_DELAY);
//touchpad_get_xy(&last_x, &last_y);
else {
//HAL_UART_Transmit(&huart6, tx_buffer2, 50, 10);
data->point.x = last_x;
data->point.y = last_y;
void lcd_color_transfer_ready_cb(SPI_HandleTypeDef *hspi)
/* CS high */
lcd_bus_busy = 0;
lv_display_flush_ready(lcd_disp);
/* Initialize LCD I/O bus, reset LCD */
static int32_t lcd_io_init(void)
/* Register SPI Tx Complete Callback */
HAL_SPI_RegisterCallback(&hspi1, HAL_SPI_TX_COMPLETE_CB_ID, lcd_color_transfer_ready_cb);
/* reset LCD */
HAL_GPIO_WritePin(LCD_RESET_GPIO_Port, LCD_RESET_Pin, GPIO_PIN_RESET);
HAL_Delay(100);
HAL_GPIO_WritePin(LCD_RESET_GPIO_Port, LCD_RESET_Pin, GPIO_PIN_SET);
HAL_Delay(100);
HAL_GPIO_WritePin(LCD_DCX_GPIO_Port, LCD_DCX_Pin, GPIO_PIN_SET);
return HAL_OK;
/* Platform-specific implementation of the LCD send command function. In general this should use polling transfer. */
static void lcd_send_cmd(lv_display_t *disp, const uint8_t *cmd, size_t cmd_size, const uint8_t *param, size_t param_size)
LV_UNUSED(disp);
while (lcd_bus_busy); /* wait until previous transfer is finished */
/* Set the SPI in 8-bit mode */
/* DCX low (command) */
HAL_GPIO_WritePin(LCD_DCX_GPIO_Port, LCD_DCX_Pin, GPIO_PIN_RESET);
/* CS low */
HAL_GPIO_WritePin(LCD_CS_GPIO_Port, LCD_CS_Pin, GPIO_PIN_RESET);
/* send command */
if (HAL_SPI_Transmit(&hspi1, cmd, cmd_size, BUS_SPI1_POLL_TIMEOUT) == HAL_OK) {
/* DCX high (data) */
/* for short data blocks we use polling transfer */
HAL_SPI_Transmit(&hspi1, (uint8_t *)param, (uint16_t)param_size, BUS_SPI1_POLL_TIMEOUT);
/* CS high */
/* Platform-specific implementation of the LCD send color function. For better performance this should use DMA transfer.
* In case of a DMA transfer a callback must be installed to notify LVGL about the end of the transfer.
static void lcd_send_color(lv_display_t *disp, const uint8_t *cmd, size_t cmd_size, uint8_t *param, size_t param_size)
LV_UNUSED(disp);
/* CS low */
/* send command */
/* for color data use DMA transfer */
/* Set the SPI in 16-bit mode to match endianness */
hspi1.Init.DataSize = SPI_DATASIZE_16BIT;
lcd_bus_busy = 1;
HAL_SPI_Transmit_DMA(&hspi1, param, (uint16_t)param_size / 2);
/* NOTE: CS will be reset in the transfer ready callback */
/* Initialize LVGL */
/* Initialize LCD I/O */
if (lcd_io_init() != 0)
return;
/* Create the LVGL display object and the LCD display driver */
lcd_disp = lv_st7789_create(LCD_H_RES, LCD_V_RES, LV_LCD_FLAG_NONE, lcd_send_cmd, lcd_send_color);
lv_display_set_rotation(lcd_disp, LV_DISPLAY_ROTATION_270);
//INIT TOUCH
/*Register at least one display before you register any input devices*/
indev = lv_indev_create();
lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER); /*See below.*/
lv_indev_set_read_cb(indev, touchpad_read); /*See below.*/
//INIT TOUCH
/* Allocate draw buffers on the heap. In this example we use two partial buffers of 1/10th size of the screen */
lv_color_t * buf1 = NULL;
//lv_color_t * buf2 = NULL;
uint32_t buf_size = LCD_H_RES * LCD_V_RES / 10 * lv_color_format_get_size(lv_display_get_color_format(lcd_disp));
buf1 = lv_malloc(buf_size);
if(buf1 == NULL) {
LV_LOG_ERROR("display draw buffer malloc failed");
return;
//buf2 = lv_malloc(buf_size);
//if(buf2 == NULL) {
// LV_LOG_ERROR("display buffer malloc failed");
// lv_free(buf1);
// return;
lv_display_set_buffers(lcd_disp, buf1, NULL, buf_size, LV_DISPLAY_RENDER_MODE_PARTIAL);
ui_init(lcd_disp);
for(;;) {
/* The task running lv_timer_handler should have lower priority than that running `lv_tick_inc` */
lv_timer_handler();
/* raise the task priority of LVGL and/or reduce the handler period can improve the performance */
osDelay(10);
static void btn_event_cb(lv_event_t * e)
lv_obj_t * btn = lv_event_get_target_obj(e);
if(code == LV_EVENT_PRESSED) {
static uint8_t cnt = 0;
cnt++;
/*Get the first child of the button which is the label and change its text*/
lv_obj_t * label = lv_obj_get_child(btn, 0);
lv_label_set_text_fmt(label, "Button: %d", cnt);
lv_obj_t * btn = lv_button_create(lv_screen_active()); /*Add a button the current screen*/
lv_obj_set_pos(btn, 0, 0); /*Set its position*/
lv_obj_set_size(btn, 160, 120); /*Set its size*/
lv_obj_add_event_cb(btn, btn_event_cb, LV_EVENT_ALL, NULL); /*Assign a callback to the button*/
lv_obj_t * label = lv_label_create(btn); /*Add a label to the button*/
lv_label_set_text(label, "Button"); /*Set the labels text*/
lv_obj_center(label);
/* USER CODE END 4 */
/* USER CODE BEGIN Header_StartDefaultTask */
* @brief Function implementing the defaultTask thread.
* @param argument: Not used
* @retval None
/* USER CODE END Header_StartDefaultTask */
/* USER CODE BEGIN 5 */
/* Infinite loop */
for(;;)
osDelay(1);
/* USER CODE END 5 */
* @brief Period elapsed callback in non blocking mode
* @note This function is called when TIM2 interrupt took place, inside
* HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
* a global variable "uwTick" used as application time base.
* @param htim : TIM handle
* @retval None
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
/* USER CODE BEGIN Callback 0 */
/* USER CODE END Callback 0 */
if (htim->Instance == TIM2)
HAL_IncTick();
/* USER CODE BEGIN Callback 1 */
/* USER CODE END Callback 1 */
* @brief This function is executed in case of error occurrence.
* @retval None
void Error_Handler(void)
/* USER CODE BEGIN Error_Handler_Debug */
/* User can add his own implementation to report the HAL error return state */
__disable_irq();
while (1)
/* USER CODE END Error_Handler_Debug */
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t *file, uint32_t line)
/* USER CODE BEGIN 6 */
/* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
Black area is where the touch is detected.
