We are upgrading the software from lvgl7.11 to lvgl8.4, but the image in RGBA3328 format as the mid resource of imgbtn has edge jagged that lvgl7.11 does not have.
mcu:stm32l451
complier: MDK v5 Complier
LVGL8.4
Use RGBA3328 as the mid resource for imgbtn
The file assets are converted through LVGL Image Converter, which is in LV_IMG_CF_TRUE_COLOR_ALPHA format and has a color bit depth of 8 bits
I experimented with RGB332, RGBA3328, RGB565, RGBA5658 image display. Here are the results:
RGB332: Aliased
RGBA3328: Aliased
RGB565: Aliased
RGBA5658: No aliasing
I generated a new RGB332 array by mixing the RGBA3328 file with the background color (0,0,0) via a python script, which shows the picture without aliasing.
static void *app_create(void *content)
ams_activity_t *activity = (ams_activity_t *)content;
lv_obj_clean(lv_scr_act()); // 清除当前屏幕的所有对象
lv_obj_t * screen2 = activity->ui = lv_obj_create(NULL);
lv_scr_load(screen2); // 加载新屏幕
lv_obj_add_event_cb(screen2, app_gesture_handle, LV_EVENT_GESTURE, NULL);
lv_obj_set_style_bg_color(screen2, lv_color_make(0, 0, 255), 0); // 设置背景颜色为蓝色
lv_obj_t * imgbtn = lv_imgbtn_create(screen2); // 创建图片按钮
lv_imgbtn_set_src(imgbtn, LV_IMGBTN_STATE_RELEASED, NULL, &output, NULL); // 设置释放状态的图片
lv_obj_set_size(imgbtn, 114, 114); // 手动设置按钮大小为100x50
lv_obj_set_pos(imgbtn, 244, 49);
printf("the output format is %d", ((lv_imgbtn_t *)imgbtn)->act_cf );
lv_imgbtn_set_src(imgbtn, LV_IMGBTN_STATE_RELEASED, NULL, &Step_count_icon, NULL); // 设置释放状态的图片
lv_obj_set_pos(imgbtn, 308, 172);
printf("the step_count_icon format is %d", ((lv_imgbtn_t *)imgbtn)->act_cf );
lv_imgbtn_set_src(imgbtn, LV_IMGBTN_STATE_RELEASED, NULL, &sleep_monitoring_icon, NULL); // 设置释放状态的图片
lv_obj_set_pos(imgbtn, 98, 295);
lv_imgbtn_set_src(imgbtn, LV_IMGBTN_STATE_RELEASED, NULL, &sedentary_reminder_icon, NULL); // 设置释放状态的图片
lv_obj_set_pos(imgbtn, 244, 295);
lv_imgbtn_set_src(imgbtn, LV_IMGBTN_STATE_RELEASED, NULL, &personnel_information_icon, NULL); // 设置释放状态的图片
lv_obj_set_pos(imgbtn, 98, 49);
lv_imgbtn_set_src(imgbtn, LV_IMGBTN_STATE_RELEASED, NULL, &date_icon, NULL); // 设置释放状态的图片
lv_obj_set_pos(imgbtn, 32, 172);
// lv_obj_t * label = lv_label_create(screen2); // 在新屏幕上添加标签
// lv_label_set_text(label, "New Screen");
// lv_obj_center(label);
// lv_obj_t * label = lv_label_create(screen2); // 创建标签并将其添加到当前屏幕
// lv_label_set_text(label, "this is a test"); // 设置标签的文本
// lv_obj_set_pos(label, 212, 350);
return activity->ui;
