I’m quite a newbie in ESP32, and recently I found that LVGL is quite interesting and would like to try to make it work on the TFT I have bought. I have tried to use the online tutorial example to run LVGL on TFT for testing. However, I found the screen is showing some glitch, like keep scanning line & it looks like noise. I had tried so many solution, however, seems like they are not resolving it.
I had tried also using XPT2046 library, however, same glitches shown.
The issue start show when I call “tft.getTouch(…)”
Do anyone have experience on this?
Any help is appreciated
ESP32-S3 Dev. Module; VSCode with PlatformIO; Framework: Arduino
TFT ILI9488 3.5", with Touch XPT2046
Latest (Master), v9.2
Getting TFT & Touch done without glitches
As included on the description above
#include <Arduino.h>
#include <lvgl.h>
#if LV_USE_TFT_ESPI
#include <TFT_eSPI.h>
/*Set to your screen resolution and rotation*/
#define TFT_HOR_RES 480
#define TFT_VER_RES 320
#define TFT_ROTATION LV_DISPLAY_ROTATION_270
/*LVGL draw into this buffer, 1/10 screen size usually works well. The size is in bytes*/
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 10 * (LV_COLOR_DEPTH / 8))
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
#if LV_USE_LOG != 0
void my_print(lv_log_level_t level, const char *buf)
LV_UNUSED(level);
Serial.println(buf);
Serial.flush();
TFT_eSPI tft;
/*Read the touchpad*/
void my_touchpad_read(lv_indev_t *indev, lv_indev_data_t *data)
// For example ("my_..." functions needs to be implemented by you)
uint16_t x, y;
bool touched = tft.getTouch(&x, &y);
if (!touched)
data->point.x = x;
data->point.y = y;
/*use Arduinos millis() as tick source*/
static uint32_t my_tick(void)
return millis();
static void btn_event_cb(lv_event_t *e)
lv_obj_t *btn = (lv_obj_t *)lv_event_get_target(e);
if (code == LV_EVENT_CLICKED)
static uint8_t cnt = 0;
cnt++;
/*Get the first child of the button which is the label and change its text*/
lv_obj_t *label = lv_obj_get_child(btn, 0);
lv_label_set_text_fmt(label, "Button: %d", cnt);
void lv_example_btn_1(void)
lv_obj_t *btn_label;
lv_obj_t *btn1 = lv_button_create(lv_screen_active());
lv_obj_add_event_cb(btn1, btn_event_cb, LV_EVENT_ALL, NULL);
lv_obj_align(btn1, LV_ALIGN_CENTER, 0, -50);
lv_obj_remove_flag(btn1, LV_OBJ_FLAG_PRESS_LOCK);
btn_label = lv_label_create(btn1);
lv_label_set_text(btn_label, "New Button");
lv_obj_center(btn_label);
void setup()
tft.init();
tft.setRotation(1);
/*Set a tick source so that LVGL will know how much time elapsed. */
lv_tick_set_cb(my_tick);
/* register print function for debugging */
#if LV_USE_LOG != 0
lv_log_register_print_cb(my_print);
lv_display_t *disp;
#if LV_USE_TFT_ESPI
/*TFT_eSPI can be enabled lv_conf.h to initialize the display in a simple way*/
disp = lv_tft_espi_create(TFT_HOR_RES, TFT_VER_RES, draw_buf, sizeof(draw_buf));
//lv_display_set_rotation(disp, TFT_ROTATION);
#else
/*Else create a display yourself*/
disp = lv_display_create(TFT_HOR_RES, TFT_VER_RES);
lv_display_set_buffers(disp, draw_buf, NULL, sizeof(draw_buf), LV_DISPLAY_RENDER_MODE_PARTIAL);
lv_indev_t *indev = lv_indev_create();
lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER); /*Touchpad should have POINTER type*/
lv_indev_set_read_cb(indev, my_touchpad_read);
lv_example_btn_1();
lv_obj_t *label = lv_label_create(lv_screen_active());
lv_label_set_text(label, "Hello Arduino, I'm LVGL!");
Serial.println("Setup done");
void loop()
delay(5); /* let this time pass */
