TFT ILI9488 + ESP32 Touch issue (using squareline studio)
Hi Guys,
I am trying to run ESP32 + TFT ILI9488 with the Squareline GUI but the touch does not work
The GUI shows up and looks good but I can’t press anything,
On touch calibration (using TFT_eSPI) the touch screen works fine, therefore, I think the issue is related to the config of lvgl or squreline code but I wasn’t able to find the root cause
my code:
#include <lvgl.h>
#include <TFT_eSPI.h>
#include "ui.h"
/*If you want to use the LVGL examples,
  make sure to install the lv_examples Arduino library
  and uncomment the following line.
#include <lv_examples.h>
/*Change to your screen resolution*/
static const uint16_t screenWidth  = 320;
static const uint16_t screenHeight = 480;
static lv_color_t buf[ screenWidth * screenHeight / 10 ];
//TFT_eSPI tft = TFT_eSPI(screenWidth, screenHeight); /* TFT instance */
TFT_eSPI tft = TFT_eSPI(screenHeight, screenWidth); /* TFT instance */
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char * buf)
    Serial.printf(buf);
    Serial.flush();
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
    uint32_t w = ( area->x2 - area->x1 + 1 );
    uint32_t h = ( area->y2 - area->y1 + 1 );
    tft.startWrite();
    tft.setAddrWindow( area->x1, area->y1, w, h );
    tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
    tft.endWrite();
    lv_disp_flush_ready( disp );
/*Read the touchpad*/
void my_touchpad_read( lv_indev_drv_t * indev_driver, lv_indev_data_t * data )
    Serial.println( "my_touchpad_read" );
    uint16_t touchX = 0, touchY = 0;
    bool touched = 0;
    touched = tft.getTouch( &touchX, &touchY, 250 );
    if( !touched )
        /*Set the coordinates*/
        data->point.x = touchX;
        data->point.y = touchY;
        Serial.print( "Data x " );
        Serial.println( touchX );
        Serial.print( "Data y " );
        Serial.println( touchY );
void setup()
    Serial.begin( 115200 ); /* prepare for possible serial debug */
    LVGL_Arduino += String('V') + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
    Serial.println( LVGL_Arduino );
    Serial.println( "I am LVGL_Arduino" );
#if LV_USE_LOG != 0
    lv_log_register_print_cb( my_print ); /* register print function for debugging */
    tft.begin();          /* TFT init */
    tft.setRotation( 4 ); /* Landscape orientation, flipped */
    uint16_t calData[5] = { 446, 3198, 301, 3464, 4 };
    tft.setTouch(calData);
    lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * screenHeight / 10 );
    /*Initialize the display*/
    /*Change the following line to your display resolution*/
    lv_disp_drv_register( &disp_drv );
    lv_indev_drv_init( &indev_drv );
    lv_indev_drv_register( &indev_drv );
    ui_init();
void loop()
    delay(5);
Does the serial monitor show the x & y values when you touch the screen?
