Hi all,
I have been able to program my ST7789 display (Cheap Yellow Display) with some code. However the look of it is appalling. The display is portrait, and the text is only slightly readable
I have programmed this with ESP-IDF. I’m finding it really hard to include this within IDF, im finding that the support is not very supporting lol. If anyone could help would be much appreciated.
It is supposed to say Hello, LVGL!
#include "lvgl.h"
#include "freertos/task.h"
#include "esp_lcd_panel_io.h"
#include "esp_lcd_panel_ops.h"
#include "esp_lcd_panel_vendor.h"
#include "driver/spi_master.h"
#include "driver/gpio.h"
#define PIN_NUM_MOSI 13
#define PIN_NUM_CLK 14
#define PIN_NUM_CS 15
#define PIN_NUM_DC 2
#define PIN_NUM_RST -1
#define PIN_NUM_BL 21 // Backlight control pin
esp_lcd_panel_handle_t panel_handle = NULL; // Global panel handle
void lvgl_flush_cb(lv_display_t *disp, const lv_area_t *area, uint8_t *px_map) {
esp_lcd_panel_draw_bitmap(panel_handle, area->x1, area->y1, area->x2 + 1, area->y2 + 1, px_map);
lv_disp_flush_ready(disp);
void lvgl_init_display(void) {
static uint8_t lvBuffer[240 * 10]; // Buffer for 10 rows
// Initialize the SPI bus
spi_bus_config_t buscfg = {
.sclk_io_num = PIN_NUM_CLK,
.mosi_io_num = PIN_NUM_MOSI,
.miso_io_num = -1,
.quadwp_io_num = -1,
.quadhd_io_num = -1,
.max_transfer_sz = 240 * 320 * 2 + 8
spi_bus_initialize(SPI2_HOST, &buscfg, SPI_DMA_CH_AUTO);
// Initialize panel IO
esp_lcd_panel_io_handle_t io_handle = NULL;
esp_lcd_panel_io_spi_config_t io_config = {
.dc_gpio_num = PIN_NUM_DC,
.cs_gpio_num = PIN_NUM_CS,
.pclk_hz = 40 * 1000 * 1000, // Use 40 MHz for stability
.spi_mode = 0,
.trans_queue_depth = 10,
.lcd_cmd_bits = 8,
.lcd_param_bits = 8
esp_lcd_new_panel_io_spi(SPI2_HOST, &io_config, &io_handle);
// Initialize the display panel
esp_lcd_panel_dev_config_t panel_config = {
.reset_gpio_num = PIN_NUM_RST,
.color_space = ESP_LCD_COLOR_SPACE_BGR, // Use BGR color space
.bits_per_pixel = 16
esp_lcd_new_panel_st7789(io_handle, &panel_config, &panel_handle);
// Reset and initialize the panel
esp_lcd_panel_reset(panel_handle);
esp_lcd_panel_init(panel_handle);
esp_lcd_panel_disp_on_off(panel_handle, true);
esp_lcd_panel_invert_color(panel_handle, false); // Disable color inversion
// Initialize backlight
gpio_reset_pin(PIN_NUM_BL);
gpio_set_direction(PIN_NUM_BL, GPIO_MODE_OUTPUT);
gpio_set_level(PIN_NUM_BL, 1); // Turn on backlight
// Create LVGL display
lv_display_t *lvDisplay = lv_display_create(240, 320);
lv_display_set_color_format(lvDisplay, LV_COLOR_FORMAT_RGB565); // Use RGB565
lv_display_set_flush_cb(lvDisplay, lvgl_flush_cb);
lv_display_set_buffers(lvDisplay, lvBuffer, NULL, 240 * 10, LV_DISPLAY_RENDER_MODE_PARTIAL);
void app_main(void) {
// Initialize LVGL
lvgl_init_display();
// Create a simple label
lv_label_set_text(label, "Hello, LVGL!");
// Main loop
while (1) {
lv_timer_handler(); // Handle LVGL tasks
