I want to make my TFT display (ILI9488 controller) black (as a black background). I’m using an object with a style that is black. I’m having an issue where these white corners will show up, almost as if the object is rounded. I’ve set the border to a width of 0.
Raspberry Pi Pico/RP2040
8.4.0
A fully black display
Looking through documentation and old forum posts to see if anyone has had the same issue.
I am not using a simulator, so I’m not sure if this code will work on the simulator, but I’m not doing something very complicated, basically just a black rectangle to fill the screen.
void home_screen() {
static lv_style_t home_style;
lv_style_init(&home_style);
lv_style_set_bg_color(&home_style, lv_color_hex(0x000000));
lv_obj_t* parent = lv_obj_create(lv_scr_act()); /*Set the screen as the parent*/
lv_obj_set_size(parent, SCREEN_WIDTH, SCREEN_HEIGHT); /*Set the size of the parent*/
lv_obj_add_style(parent, &home_style, LV_PART_MAIN);
lv_obj_set_style_clip_corner(parent, true, 0);
lv_style_set_border_width(&home_style, 0);
