I have been trying to port lvgl to stm32h7b3i-dk based on the official demo for the stm32f746 discovery board for about 2 months. However, I still cannot get it to show anything other than a white screen. I believe the problem is with my tft.c file as my other files (touchscreen.c…) are more or less the same.
STM32H7B3I-DK
V8.0
To port LVGL to stm32h7b3i-dk.
I have tried to edit the BSP lcd driver for stm32h7b3i-dk as I noticed that there official demo does not include the lcd driver as it is merged into the tft.c file. However, all I managed to do is display an empty white screen. Now I have included the BSP LCD driver file and am just calling the functions in the tft.c file as shown below. However, it still does not work and I am unsure why.
I would be grateful if anyone could provide me with some guidance here. Thank you for your time and help!
/* Includes ------------------------------------------------------------------*/
//#include "../../Core/Inc/main.h"
#include "../../lv_conf.h"
#include "../../lvgl/lvgl.h"
#include <string.h>
#include <stdlib.h>
#include "tft.h"
#include "../../Drivers/CMSIS/Device/ST/STM32H7xx/Include/stm32h7xx.h"
#include "../../Drivers/BSP/STM32H7B3I-DK/stm32h7b3i_discovery.h"
#include "../../Drivers/BSP/STM32H7B3I-DK/stm32h7b3i_discovery_lcd.h"
#include "../../Drivers/BSP/STM32H7B3I-DK/stm32h7b3i_discovery_sdram.h"
#include "../../Drivers/BSP/STM32H7B3I-DK/stm32h7b3i_discovery_ts.h"
#include "../../Drivers/BSP/Components/rk043fn48h/rk043fn48h.h"
* DEFINES
#define LCD_FB_START_ADDRESS 0xD0000000
* STATIC PROTOTYPES
/*These 3 functions are needed by LittlevGL*/
static void ex_disp_flush(lv_disp_drv_t *drv, const lv_area_t *area, lv_color_t * color_p);
static void ex_disp_clean_dcache(lv_disp_drv_t *drv);
* STATIC VARIABLES
#if LV_COLOR_DEPTH == 16
typedef uint16_t uintpixel_t;
#elif LV_COLOR_DEPTH == 24 || LV_COLOR_DEPTH == 32
typedef uint32_t uintpixel_t;
/* You can try to change buffer to internal ram by uncommenting line below and commenting
* SDRAM one. */
//static uintpixel_t my_fb[TFT_HOR_RES * TFT_VER_RES];
static __IO uintpixel_t * my_fb = (__IO uintpixel_t*) (0x60000000);
static DMA_HandleTypeDef DmaHandle;
static int32_t x1_flush;
static int32_t y1_flush;
static int32_t x2_flush;
static int32_t y2_fill;
static int32_t y_fill_act;
static const lv_color_t * buf_to_flush;
static lv_disp_t *our_disp = NULL;
* MACROS
void tft_init(void)
/* There is only one display on STM32 */
if(our_disp != NULL)
abort();
/* LCD Initialization */
//LCD_Init();
BSP_LCD_Init(0, LCD_ORIENTATION_LANDSCAPE);
/* Enable the LCD */
BSP_LCD_DisplayOn(0);
//DMA_Config();
* Create a buffer for drawing
/* LittlevGL requires a buffer where it draws the objects. The buffer's has to be greater than 1 display row*/
static lv_disp_draw_buf_t disp_buf_1;
static lv_color_t buf1_1[TFT_HOR_RES * 68];
static lv_color_t buf1_2[TFT_HOR_RES * 68];
lv_disp_draw_buf_init(&disp_buf_1, buf1_1, buf1_2, TFT_HOR_RES * 68); /*Initialize the display buffer*/
disp_drv.hor_res = 480;
disp_drv.ver_res = 272;
disp_drv.flush_cb = ex_disp_flush;
disp_drv.clean_dcache_cb = ex_disp_clean_dcache;
/*Set a display buffer*/
disp_drv.draw_buf = &disp_buf_1;
our_disp = lv_disp_drv_register(&disp_drv);
* STATIC FUNCTIONS
/* Flush the content of the internal buffer the specific area on the display
* You can use DMA or any hardware acceleration to do this operation in the background but
* 'lv_flush_ready()' has to be called when finished
* This function is required only when LV_VDB_SIZE != 0 in lv_conf.h*/
int32_t x1 = area->x1;
int32_t x2 = area->x2;
int32_t y1 = area->y1;
int32_t y2 = area->y2;
/*Return if the area is out the screen*/
if(x2 < 0) return;
if(y2 < 0) return;
if(x1 > TFT_HOR_RES - 1) return;
if(y1 > TFT_VER_RES - 1) return;
int32_t act_x1 = x1 < 0 ? 0 : x1;
int32_t act_y1 = y1 < 0 ? 0 : y1;
int32_t act_x2 = x2 > TFT_HOR_RES - 1 ? TFT_HOR_RES - 1 : x2;
int32_t act_y2 = y2 > TFT_VER_RES - 1 ? TFT_VER_RES - 1 : y2;
x1_flush = act_x1;
y1_flush = act_y1;
x2_flush = act_x2;
y2_fill = act_y2;
y_fill_act = act_y1;
buf_to_flush = color_p;
SCB_CleanInvalidateDCache();
SCB_InvalidateICache();
/*##-7- Start the DMA transfer using the interrupt mode #*/
/* Configure the source, destination and buffer size DMA fields and Start DMA Stream transfer */
/* Enable All the DMA interrupts */
HAL_StatusTypeDef err;
uint32_t length = (x2_flush - x1_flush + 1);
#if LV_COLOR_DEPTH == 24 || LV_COLOR_DEPTH == 32
length *= 2; /* STM32 DMA uses 16-bit chunks so multiply by 2 for 32-bit color */
err = HAL_DMA_Start_IT(&DmaHandle,(uint32_t)buf_to_flush, (uint32_t)&my_fb[y_fill_act * TFT_HOR_RES + x1_flush],
length);
if(err != HAL_OK)
while(1); /*Halt on error*/
