lv_indev_read_task: indev read task started but never finishes.
Adafruit Feather M4 using the FeatherWing TFT with TS input.
What do you experience?
Happens frequently when using touch screen input to trigger buttons etc. The buttons get “stuck” inbetween states and essentially pause all task handling.
What do you expect?
Task handler should never pause and whatever infinite loops it iswaiting on needs to timeout, or I need to have a way to handle the timeout in the touch screen callback (maybe I already can? but not sure how to do so).
Nothing specific, any button I create since I started using LVGL has done this… also tabs in tabviews etc. It’s not widget specific, it’s related to the touch screen handling.
TS callback looks like this:
bool input_ts(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
TouchPoint p;
// save the state and save the pressed coordinate
data->state = ts.touched() ? LV_INDEV_STATE_PR : LV_INDEV_STATE_REL;
if (data->state == LV_INDEV_STATE_PR)
p = ts.getPoint();
last_y = map(p.x, TS_MINX, TS_MAXX, 0, tft.height());
last_x = map(p.y, TS_MINY, TS_MAXY, 0, tft.width());
// set the coordinates (if released use the last pressed coordinates)
data->point.x = last_x;
data->point.y = last_y;
return !ts.bufferEmpty();
TRACE level logs look like this (you can see a normal task handler output with my own logging in the middle, then the failed task handling ending in an infinite loop of indev stop and start read):
TRACE: File: .pio/libdeps/adafruit_feather_m4/lvgl/src/lv_core/lv_indev.c129: _lv_indev_read_task: indev read task finished
TRACE: File: .pio/libdeps/adafruit_feather_m4/lvgl/src/lv_core/lv_indev.c77: _lv_indev_read_task: indev read task started
TRACE: File: .pio/libdeps/adafruit_feather_m4/lvgl/src/lv_hal/lv_hal_indev.c153: _lv_indev_read: idnev read started
TRACE: File: .pio/libdeps/adafruit_feather_m4/lvgl/src/lv_hal/lv_hal_indev.c155: _lv_indev_read: idnev read finished
F: 0 0 <=> 1 0 0, 0 0 <=> 1 0 1, 1 0 <=> 2 0 0, 1 1 <=> 2 0 1, 2 1 <=> 1 1 1, FOUND
D: 2 1 <=> 1 1 1,
C: 0 0 <=> 1 1 1,
TRACE: File: .pio/libdeps/adafruit_feather_m4/lvgl/src/lv_core/lv_refr.c177: _lv_disp_refr_task: lv_refr_task: started
TRACE: File: .pio/libdeps/adafruit_feather_m4/lvgl/src/lv_core/lv_refr.c310: _lv_disp_refr_task: lv_refr_task: ready
(TO INFINITY AND BEYOND!!!)
When “stuck”, buttons have a STATE that is inbetween PRESSED and RELEASED (I have other photos but can only upload one):
