lv_sim_visual_studio
What do you experience?
What do you expect?
First create a tileview, there are two tiles. Click on the second tile to create a tabview, the tabview has two tabs, the program will automatically jump to the second tab, right slide on the second tab will delete the tabview. When repeatedly right slide several times, the right slide will fail.
Add a code snippet to reproduce the issue in the simulator. It should contain only the relevant code which can be compiled. Bug reports without code snippets or with erroneous code snippets will not be reviewed.
static lv_obj_t *tabview = NULL;
static lv_obj_t *parentObj = NULL;
static lv_obj_t *tileview = NULL;
static void TabviewEventHandler(lv_obj_t *tabview, lv_event_t event)
if (event == LV_EVENT_VALUE_CHANGED) {
uint16_t curIndex = lv_tabview_get_tab_act(tabview);
if (curIndex == 0) {
lv_obj_del(tabview);
static void ObjEventHandle(lv_obj_t *obj, lv_event_t event)
if (event == LV_EVENT_SHORT_CLICKED) {
tabview = lv_tabview_create(obj, NULL);
lv_obj_set_size(tabview, LV_HOR_RES_MAX, LV_VER_RES_MAX);
lv_tabview_set_btns_pos(tabview, LV_TABVIEW_TAB_POS_NONE);
lv_obj_t *tab1 = lv_tabview_add_tab(tabview, "Tab1");
lv_obj_t *tab2 = lv_tabview_add_tab(tabview, "Tab2");
lv_page_set_scrlbar_mode(tab2, LV_SCRLBAR_MODE_OFF);
lv_page_set_scrlbar_mode(tab1, LV_SCRLBAR_MODE_OFF);
lv_obj_set_event_cb(tabview, TabviewEventHandler);
lv_obj_t *label = lv_label_create(tab2, NULL);
lv_label_set_text(label, "Scroll right to exit the tabview");
lv_obj_align(label, NULL, LV_ALIGN_CENTER, 0, 0);
lv_tabview_set_tab_act(tabview, 1, LV_ANIM_OFF);
void tabviewTest()
static lv_point_t validPos[2] = { { 0, 0 }, {0, 1} };
tileview = lv_tileview_create(lv_scr_act(), NULL);
lv_tileview_set_valid_positions(tileview, validPos, 2);
lv_obj_set_size(tileview, LV_HOR_RES_MAX, LV_VER_RES_MAX);
lv_page_set_scrlbar_mode(tileview, LV_SCRLBAR_MODE_OFF);
lv_obj_t * tile1 = lv_obj_create(tileview, NULL);
lv_obj_set_pos(tile1, 0, 0);
lv_obj_set_size(tile1, LV_HOR_RES_MAX, LV_VER_RES_MAX);
lv_obj_t *label = lv_label_create(tile1, NULL);
lv_label_set_text(label, "tile1,Scroll up to tile2");
lv_tileview_add_element(tileview, tile1);
lv_obj_t * tile2 = lv_obj_create(tileview, NULL);
lv_obj_set_pos(tile2, 0, LV_VER_RES_MAX);
lv_obj_set_size(tile2, LV_HOR_RES_MAX, LV_VER_RES_MAX);
label = lv_label_create(tile2, NULL);
lv_label_set_text(label, "tile2,Click to create a tabview");
lv_obj_set_click(tile2, true);
lv_obj_set_event_cb(tile2, ObjEventHandle);
lv_tileview_add_element(tileview, tile2);
int main(int argc, char** argv)
/*Initialize LittlevGL*/
/*Initialize the HAL for LittlevGL*/
hal_init();
tabviewTest();
while (1) {
/* Periodically call the lv_task handler.
* It could be done in a timer interrupt or an OS task too.*/
lv_task_handler();
Sleep(10); /*Just to let the system breathe */
return 0;
