Tabview buttons initialization event
I debute with UI in generally, and i use LVGL that i find very good Library,
i’m using Tabview in tabview to constitute a menu bar in bottom of screen, and i want to change the shape of buttons (for example : add a vertical line between buttons) ,
and i noticed that the first button is activate (checked) in first use, so we see the content of the first tab, is there a possibility in tabview to make all tabs not checked, (for example : press second time in button make it not checked, and hide the main part of tab) ?
Codeblocks Simulator
800 * 480
8.1.0
What do you want to achieve?buttons zone
How to :
  • uncheck all buttons (Container for the tabs must disapear)
  • change shape of buttons ,
