Tabview bar randomly expands or change color
Hi everybody,
I’m struggling with two very disappointing bugs(?) which sometimes makes my application unusable.
I’m using a tabview with 4 tabs, one of which have some textboxes with a related keyboad event (taken from the keyboard example).
1)
When I slide to that tab and press on a textbox, the keyboard appears, but contemporary the upper tabview bar expands in height covering half the screen. Then, when I close the keyboard the bar expands to the whole screen and it’s impossible to do anything else, except force closing the app.
I’ve tried to add some sleeps while creating the graphics to avoid eventual errors, but nothing changed.
2)
Sometimes the tabview bar color randomly change to green or transparent even if I set it statically at application start.
I’m using LVGL on a reTerminal with Raspberry Lite OS (64 bit) and C++.
Thanks in advance for your support.
Alessandro
The first is the normal visualization, the others are the reported bugs
Regarding the keyboard issue: can you share a minimal code snippet to show how you do it?
Regarding the color changing issue: please create a video about it.
Hi, sorry for the delay. I’ll give you my main menu code.
Regarding the changing color I think a video would be useless because it changes color at the beginning of the program execution and it stucks with that color for the whole session.
void lv_menu_imx(bool graphics, IMX *imx)
    if (LV_HOR_RES <= 320)
        disp_size = DISP_SMALL;
    else if (LV_HOR_RES < 720)
        disp_size = DISP_MEDIUM;
        disp_size = DISP_LARGE;
    lv_imx = imx;
    lv_ini.load_file("config.ini");
    lv_config = lv_ini.get_data();
    tab_h = 70;
    font_num = &openSans_500;
    font_sfCompact = &sfCompactDisplay_25;
    font_ip = &openSans_30;
    font_large = &roboto_32;
    font_normal = &roboto_25;
    font_small = &roboto_18;
    font_slider = &robotoBold_25;
    font_sliderB = &robotoBold_40;
    long size;
    char *buf;
    size = pathconf(".", _PC_PATH_MAX);
    if ((buf = (char *)malloc((size_t)size)) != NULL)
        ptr = getcwd(buf, (size_t)size);
#if LV_USE_THEME_DEFAULT
    lv_theme_default_init(NULL, lv_palette_lighten(LV_PALETTE_BLUE, NULL), lv_palette_main(LV_PALETTE_RED), LV_THEME_DEFAULT_DARK, &lv_font_montserrat_24);
    initGrid();
    sleep(0.1);
    lv_style_init(&transparent_style);
    lv_style_set_bg_opa(&transparent_style, LV_OPA_0);
    lv_style_set_border_width(&transparent_style, 0);
    //Completely transparent button except inside icon
    lv_style_init(&stransp_btn_style);
    lv_style_set_bg_opa(&stransp_btn_style, LV_OPA_TRANSP);
    lv_style_set_border_opa(&stransp_btn_style, LV_OPA_TRANSP);
    lv_style_set_outline_opa(&stransp_btn_style, LV_OPA_TRANSP);
    lv_style_set_shadow_opa(&stransp_btn_style, LV_OPA_TRANSP);
    lv_style_init(&style_text_muted);
    lv_style_set_text_opa(&style_text_muted, LV_OPA_50);
    lv_style_init(&style_normal);
    lv_style_set_text_font(&style_normal, font_normal);
    lv_style_init(&style_title);
    lv_style_set_text_font(&style_title, font_large);
    lv_style_init(&style_ip);
    lv_style_set_text_font(&style_ip, font_ip);
    lv_style_init(&style_bullet);
    lv_style_set_radius(&style_bullet, 50);
    lv_style_set_bg_opa(&style_bullet, LV_OPA_COVER);
    lv_style_set_bg_color(&style_bullet, lv_color_make(0, 124, 170));
    lv_style_set_border_side(&style_bullet, LV_BORDER_SIDE_RIGHT);
    lv_style_init(&round_style);
    lv_style_set_radius(&round_style, 50);
    lv_style_set_bg_opa(&round_style, LV_OPA_COVER);
    lv_style_set_border_side(&round_style, LV_BORDER_SIDE_RIGHT);
    lv_style_init(&style_tv);
    lv_style_set_bg_color(&style_tv, lv_color_make(0, 40, 56));
    lv_style_set_bg_opa(&style_tv, LV_OPA_COVER);
    lv_style_init(&knob_style);
    lv_style_set_bg_color(&knob_style, lv_color_make(255, 255, 255));
    lv_style_init(&login_style);
    lv_style_set_bg_color(&login_style, lv_color_make(0, 40, 56));
    lv_style_set_border_color(&login_style, lv_color_make(112, 112, 112));
    lv_style_set_border_opa(&login_style, LV_OPA_100);
    lv_style_set_border_width(&login_style, 5);
    lv_style_init(&white_style);
    lv_style_set_text_color(&white_style, lv_color_make(255, 255, 255));
    lv_style_init(&black_style);
    lv_style_set_text_color(&black_style, lv_color_make(0, 0, 0));
    // Creazione numero camera e status led
    lv_style_init(&camera_color_style);
    lv_style_set_text_color(&camera_color_style, lv_color_make(lv_config.label_R, lv_config.label_G, lv_config.label_B));
    lv_style_init(&num_style);
    lv_style_set_bg_opa(&num_style, LV_OPA_0);
    lv_style_set_border_color(&num_style, lv_color_make(198, 209, 216));
    lv_style_set_border_opa(&num_style, LV_OPA_COVER);
    lv_style_set_border_width(&num_style, 5);
    lv_obj_t *win;
    win = lv_label_create(lv_scr_act());
    lv_label_set_text(win, "");
    lv_obj_set_width(win, 1280);
    lv_obj_set_height(win, 720);
    lv_obj_align_to(win, lv_scr_act(), LV_ALIGN_CENTER, 0, 0);
    // lv_obj_add_style(win, &style_tv, LV_PART_MAIN);
    lv_obj_clear_flag(win, LV_OBJ_FLAG_SCROLLABLE);
    bg_img = lv_img_create(win);
    lv_img_set_src(bg_img, &bgReterminal);
    lv_obj_align(bg_img, LV_ALIGN_CENTER, 0, 0);
    lv_obj_set_size(bg_img, 1280, 720);
    // lv_obj_add_style(lv_scr_act(), &style_tv, LV_PART_MAIN);
    lv_obj_clear_flag(lv_scr_act(), LV_OBJ_FLAG_SCROLLABLE);
    // Creazione e posizionamento tab
    tv = lv_tabview_create(lv_scr_act(), LV_DIR_TOP, tab_h);
    lv_obj_add_style(tv, &transparent_style, LV_PART_MAIN);
    lv_obj_align(tv, LV_ALIGN_TOP_LEFT, -30, 10);
    lv_obj_set_width(tv, 1290);
    num_btn = lv_btn_create(lv_scr_act());
    lv_obj_remove_style_all(num_btn);
    lv_obj_align(num_btn, LV_ALIGN_TOP_RIGHT, -120, 10);
    lv_obj_set_size(num_btn, 70, 70);
    lv_obj_add_style(num_btn, &num_style, 0);
    lv_obj_add_style(num_btn, &style_title, LV_PART_MAIN);
    lv_obj_set_style_radius(num_btn, LV_RADIUS_CIRCLE, 0);
    label_num_button = lv_label_create(num_btn);
    char num[4];
    (lv_config.camera_num < 10) ? sprintf(num, "0%d", lv_config.camera_num) : sprintf(num, "%d", lv_config.camera_num);
    lv_label_set_text(label_num_button, num);
    lv_obj_add_style(label_num_button, &camera_color_style, 0);
    lv_obj_set_style_text_font(label_num_button, font_ip, LV_PART_MAIN);
    lv_obj_align(label_num_button, LV_ALIGN_CENTER, 0, 3);
    status_led = lv_led_create(lv_scr_act());
    lv_obj_align(status_led, LV_ALIGN_TOP_RIGHT, -10, 10);
    lv_obj_set_size(status_led, 70, 70);
    lv_led_on(status_led);
    lv_obj_add_event_cb(tv, scrolling, LV_EVENT_VALUE_CHANGED, NULL);
    lv_obj_set_style_text_font(lv_scr_act(), font_large, LV_PART_ANY);
    if (disp_size == DISP_LARGE)
        lv_obj_t *tab_btns;
        lv_obj_t *logo;
        lv_style_init(&style_tab);
        lv_style_set_border_width(&style_tab, 0);
        lv_style_set_border_opa(&style_tab, LV_OPA_0);
        tab_btns = lv_tabview_get_tab_btns(tv);
        lv_obj_add_style(tab_btns, &style_bullet, LV_PART_MAIN);
        lv_obj_add_style(tab_btns, &white_style, LV_PART_MAIN);
        lv_obj_add_style(tab_btns, &style_title, LV_PART_MAIN);
        lv_obj_add_style(tab_btns, &style_tab, LV_PART_MAIN);
        lv_obj_set_width(tab_btns, 1080);
        lv_obj_add_event_cb(tab_btns, tab_btns_click, LV_EVENT_VALUE_CHANGED, tv);
        logo = lv_img_create(tab_btns);
        lv_img_set_src(logo, &bts_logo);
        lv_obj_set_style_pad_left(tab_btns, LV_HOR_RES / 2 - 250, 0);
        lv_obj_align(logo, LV_ALIGN_LEFT_MID, -LV_HOR_RES / 2 + 300, 0);
    t1 = lv_tabview_add_tab(tv, "INFO");
    t2 = lv_tabview_add_tab(tv, "LIVE");
    t3 = lv_tabview_add_tab(tv, "SETTINGS");
    if(graphics)
        // START DRAW
        drawTH = std::thread(drawImgBufferIMX);
        drawTH.detach();
    tab_camera_info(t1);
    sleep(0.1);
    tab_img_live(t2);
    sleep(0.1);
    tab_settings(t3);
    // Remove scroll flag from tabs
    lv_obj_clear_flag(t1, LV_OBJ_FLAG_SCROLLABLE);
    lv_obj_clear_flag(t2, LV_OBJ_FLAG_SCROLLABLE);
    lv_obj_clear_flag(t3, LV_OBJ_FLAG_SCROLLABLE);
I wanted to try the code but there a lot of undefined variables, types and app specific stuff in it.
Could you create a simple targeted code to demonstrate only the issue. Which I can copy paste and compile.
